question about being at a stop or light
Old Sep 30, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
Is the reason to be in neutral at stop signs or traffic lights this: if you have it in first the whole time you're depressing the clutch pedal at every stop or light then you're putting a lot of extra load/work on the pressure plate. obviously, this will be detrimental to the pressure plate compared to just being in neutral a lot of the times to give the plate a "breather." What do you guys think?
Old Sep 30, 2002
Ducatti's Avatar
Ducatti is an unknown quantity at this point
My reason is because I don't want my foot in for 2 minutes, im lazy, I dont care what it does to my car
Old Sep 30, 2002
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
yeah, it increases load on the pressure plate. I was in traffic once during NY rush and it was stop and go for like an hour. My old car's pressure plate heat up, and when it was time to go, i gave it gas and went nowhere until it cooled.
Old Sep 30, 2002
vietstylez's Avatar
mostly cuz of laziness......
Old Sep 30, 2002
JoeB16's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
JoeB16 is an unknown quantity at this point
yes, it puts wear on the clutch/pp/flywheel to keep it depressed for long periods of time. plus with my 6 puck clutch of death, id have 1 leg that looks like it belongs to a pro wrestler if i did that all the time.
Old Sep 30, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
if you leave the clutch pedal pressed at lights, your slave cylinder will develop leaks. when this happens your clutch pedel will be pressed but your car will be trying to constantly drive (it doesnt life the two plates apart fully) so most likely stall if youre at a light.
im pretty sure thats correct, but you might wanna check me.
Old Sep 30, 2002
sspem2's Avatar
em2
i put it in neutral when im at a light. keep your clutch as long as possible.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
trellex
May 24, 2015 04:39 PM
McD
Apr 29, 2015 03:50 PM
tylerginevan
Apr 27, 2015 12:29 PM
Grazzhopper
Nov 11, 2001 08:06 AM
