Honda Civic D17a2 ticking noise Please help
Old Oct 29, 2018
TripleJay's Avatar
TripleJay is an unknown quantity at this point
Don’t know what this sound is it ticked/clicks when I’m on the gas. Don’t hear it at idle .any help would be appreciated here is a YouTube link of the noise
Old Oct 29, 2018
Colin42's Avatar
Re: Honda Civic D17a2 ticking noise Please help
Check your heat shields?
Manifold might be cracked
Old Oct 29, 2018
I can't hear squat in the video, maybe it's just this laptop.
Based on written description alone I'd expect exhaust leaks in the area of the manifold. More investigation needed?
Old Oct 29, 2018
TripleJay's Avatar
Weird you don’t hear it, gets louder at the end of the videos kind of a higher pitch sound. I will check into the exhaust, thank you
Old Oct 29, 2018
TripleJay's Avatar
will check into those thank you
Old Nov 29, 2018
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Did you figure this out yet? Start with simple things first, like heat shields. My D17A2 started to do the same thing for no reason a few years ago. It ticked like yours when revving it up, but not at idle or while cruising at a low RPM. I narrowed it down to cylinder number 2 by unplugging the coils while the motor was running. When I shut off cylinder 2, the noise stopped. I'm not sure what exactly was making that noise, I think it was a piston or wrist pin. But I do know that a few months later, the motor started making horrible noises going down the highway, and a few minutes later, it blew up. When I tore the engine down, I found that the number 2 piston fell apart while I was driving, and the rod put a hole in the block. Hopefully yours is something simple though.
Old Nov 29, 2018
TripleJay's Avatar
haven’t looked into it yet, parked it for the winter but I will keep that in mind when I get to it. Thank you (not sure why there is a line through this lol)
Old Nov 29, 2018
Ok, let me know if you need any help. I'm always willing to help.
Old Dec 5, 2018
Thepuma's Avatar
Thepuma is an unknown quantity at this point
Well you might have helped me. Have had the car for two years now, long story short it was almost impossible to hear anything with input shaft bearing bad. After I rebuilt the transmission this summer. I have noticed a weird tick in the motor so I'll have to test it. Thank you
Old Dec 5, 2018
It probably needs a valve adjustment. Honda engines need a valve adjustment from time to time since they have a solid valvetrain. The spec is 9 thousandths of an inch for the intake, and 11 thousandths for the exhaust. The valve adjustment may not be it, but it's a good place to start since it's free, easy, and relatively quick.
rockyrock
Oct 11, 2017 12:27 PM
UMrk
Feb 12, 2015 07:04 PM
mdrake1
Bolt-on Engine Performance
Dec 21, 2013 12:50 AM
jeggett
Apr 13, 2013 06:03 PM
Linch
Oct 22, 2008 11:27 PM
