Yupp need help after rebuild.
Old Jun 22, 2011
02civicsi02's Avatar
Low and slow!
Ok guys need a couple suggestions on what to check. First off my wifes car is a 97 integra ls b18b1 and been sittin for bout 8 months and I have rebuilding it. I had to take off the head and rebuild it. I put a new headgasket on it. I put the car together and everything timing is perfect everything hooked up right as I kno. Started it up yesterday for the first time and cranked up and let it run to get the oil flowin good and ran good. Went to drive it home cause was at a friends and got halfway home and stopped at a stop sign and it wouldn't go anywhere. When I give it gas it dies but will crank right up rev low at first but then rise up to normal. It is low on gas also.
Now I think that it might be low fuel pressure, bad gas, or something. I am going to check the vacuum hoses, take valve cover off to check and see if oil flowed good to the head, put gas in it, check sensors and stuff. Anyone have any ideas on wat is up.
Old Jun 27, 2011
Low and slow!
Re: Yupp need help after rebuild.
Come on guys someone has to kno something. Does obd2 valves, springs work in a obd0 head. Cause I had a obd2 head took the valves out and put them in a obd0 head. Maybe they don't work cause they might not seal right or something. I torqued the head studs down right but we checked the compression and 4th cylinder was 150, 3rd cylinder 140, 2nd cylinder 120, and 1st cylinder 110. Now the head gasket I put on it is probably blown, but got a warranty on it. Now maybe the head was warped or something, needs a resurface. Some one throw some suggestions out
Old Jun 27, 2011
head warped maybe? I was waiting to hear the diagnosis of the fuel...
Old Jun 28, 2011
Low and slow!
The head being warped is really the only thing I can think of besides the obd2 valves not workin in a obd0 head but I really don't think that's it. I took the cams out and checked the head studs and was still torqued down to the right specs. I took off the head and checked the gasket if it had a good seal and it didn't looked like it sealed good so the only thing I can think of is that head is warped which is causing the compression to be low on 2 cylinders. I got that obd0 head for free so really didn't hurt me any. Only thing I think I could do now is swap the valves back into the other head I have a try it out
Old Jun 28, 2011
mac25's Avatar
Dr Krieger of Modification
wish i could help bro, good luck. ps love you avatar pic =D. any chance you didn't tighten or clip something in all the way and it vibrated out? once i had a half clipped sparkplug and it started fine but then died witha horrible sound. i'd say to check all hoses and clips again even if they look tight.
Old Jun 28, 2011
Kennykid2002's Avatar
Kenny the Ricer
Just throwin it out there, could be old bad gas
& engine could maybe use some seafoam
Old Jun 28, 2011
BlueEM2's Avatar
Whachya lookin at?
You need to check the ECU for codes to see if it's throwing one. Even if the head gasket is not sealing properly the car should start unless it's so bad the cylinders are getting flooded with coolant. Get the head checked out for trueness and your codes read is where I'd start.
97-DX-Lover
Jun 14, 2015 06:07 PM
Nycrew024
Mar 23, 2015 12:07 AM
RafBys629
Feb 20, 2015 02:34 PM
OTCTurboDiesel
Sep 13, 2014 05:39 AM
Tkdking3
Feb 10, 2012 11:59 PM
