3rd week into automotive school
Old Mar 9, 2006
  #31
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
my teacher said something like cars are like people we have a bigger moouth than assssshole some comparison O_O lol but i remembered it
Old Mar 9, 2006
  #32
crazea03's Avatar
crazea03 will become famous soon enough
was dat towards me?
Old Mar 9, 2006
  #33
well for the intake comparision he taught us that way O_O nvm lol
Stay in school kids dont do drugs
Old Mar 9, 2006
  #34
crazea03's Avatar
oh ok
i was about blackout on you lmao im just playin
Old Mar 9, 2006
  #35
ncirom2003's Avatar
Originally Posted by crazea03
ok which valve is usually bigger the exhaust or intake?
name the parts on the crankshaft?
how do u know which way a piston should be put on? easy one
take that mr. smarty pants, lol
the intake because the exhaust valve needs to have a smaller surface area to prevent it from burning up because your pushing open against the built up pressure and heat.
counter weight's journals all ya need to kno
a piston should be put with the notification dot facing the front of the engine if they have one.
now your turn.
define open and closed loop?
what does a rectifier on an alternator do?
whats the difference between a strut and a shock absorber?
whats the difference between sliding and floating and fixed calipers?
what is a dtc and how does it come up?
what is ROM and whats on it?
Old Mar 9, 2006
  #36
eddiechaps's Avatar
i love my morreale
my friend went tot hat school it's good stuff i plan on going there sometime soon. hey crazea03 need a roommate?
Old Mar 9, 2006
  #37
now your turn.
i know those answers but i dont know what Rom is and what does rectifier on an alternator do?
Old Mar 9, 2006
  #38
crazea03's Avatar
now your turn.
whoa whoa buddy basic engines first im not like master like you are remember third week in school
nah i dont sorry edddie, but there is a bunch of kids looking for roommates just let me know when you starting and ill help you out
Old Mar 9, 2006
  #39
eddiechaps's Avatar
i love my morreale
probably next spring. gotta save som money up & stuff.
Old Mar 9, 2006
  #40
NCSUEngineer84's Avatar
NCSUEngineer84 is an unknown quantity at this point
Wow, someone posted saying all you needed to know about electricity was Ohm's law. Haha, that is the most unfounded statement. Try taking an electrical engineering class. That will give you a small taste of what you actually have to know about electricity to actually understand what goes on inside the ECU. You should at least know how to analyze a circuit using Kirchoff's Voltage and Current Laws.
Old Mar 9, 2006
  #41
ncirom2003's Avatar
he meant thats all you need to know to test and diagnose a 12v dc car circuit, it was still incorrect but thats all he meant.
lol just bustin ya ***** man, im no master trust me ahahaha youll learn all that soon enough.
boxcar, the rom is read only memory and it holds the vehicles working parameters meaning it has the info that say the car can only run this lean or this rich and if its outside of those parameters u get a cel, the ecm sees a voltage from 02, refers to the rom then rom tells ecu is good or not, then ecu will send dtc or not.
Old Mar 9, 2006
  #42
yeah thats all electric class that i didnt go to but he didint go into it as detailed as you....all we talked about was Ohms law and yeah thats basic not "Try taking an electrical engineering class." no....i wont try taking that class becuase it boring and im a automotive student i cant concentrate all my diagnosing on electrical problems
Old Mar 9, 2006
  #43
Yeah, I am just being a smarty pants. We are studying complex power, capacitance, and impedance in my ECE class. We studied the Otto and Diesel cycles in my Thermodynamics class. Fun stuff, sike! You got to be pretty electrical minded these days. Most mechanical components are monitored by sensors and feedback devices.
Old Mar 9, 2006
  #44
ncirom2003's Avatar
isnt kirchoff's for alternating current?
Old Mar 14, 2006
  #45
UTICivic's Avatar
UTICivic will become famous soon enoughUTICivic will become famous soon enough
Eww you go to UTI? LOL.
I graduated from the Rancho school in November of 05.
I work at Washinton Mutual making 21 dollars an hour. I really dont even know WHY i wasted 25 precious thousand dollars to go there...
Old Mar 14, 2006
  #46
fluk3d's Avatar
fluk3d is on a distinguished road
putting sythentic oil is no different than conventional cuz it has the same the additives , and it helps to lengthening the time of when to change your oil but you still have to replace the filter every 3000 miles so there is no point for anyone to be using synthentic oil. its out there but no point. and should read the ratings on the back of the bottles.
ratings
sm- for 05 vehicles and down
sl- for 04 and down
sj- for 01 and down
sh- obsolete - not recommended for gasoline combustion engines-you can use it gardening tools but not for cars
you can sm for any vehicle from 1979-2005
you cannot use lower rating oils in newer vehicles
meaning you cannot use sl rating oil in an 05 cuz sm has more additives in the oil.
check it -> carcraft.com/techarticles/15378/
sorry can't put http i havent reached 15 limit post
Old Apr 6, 2006
  #47
teg91ls's Avatar
teg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trusted
sythetic oil has been proven to not break down as fast as conventional oil under high temperatures. It protects longer and under more agressive driving conditions and higher temps
Old Apr 6, 2006
  #48
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
Crazea before they (your teachers) go into the speils about how ASE certs are the best damn thing in the world, let me tell you they''re not.....it s non-profit (supposedly) organization, htta makes up b/s tests that only test how well you can either remember **** for a 4 hour test, or how well you can study.....nothing hands on, thats what really counts. all ASE is, is afriggin badge on your shirt, and a paper in your toolchest.
^^^this steming from your 'professor' saying he is an ASE master mechanic. I know some guys at my job that have the master mechanic status and don't know how to dissassmble a caliper.
Old Apr 6, 2006
  #49
ncirom2003's Avatar
ive got 3 ase's, and i actually agree with shroomster. they are easy to get if you study, but they dont just show that, they show that you not only know how to remove and replace parts. it shows you understand how they work and how to diagnose them, its a huge part of car repair. and ase's are such a staple in this field for that reason, just as any other cert. is.
BootyDo
Jun 21, 2016 03:45 PM
stvpagn
Jul 9, 2015 09:59 PM
AaronSorenson
Jul 7, 2015 09:40 PM
Mnealo
Jun 18, 2015 10:11 PM
SSMatey
Apr 13, 2015 06:09 PM
