how much ATF for change?
Old Mar 3, 2006
Cypher's Avatar
Cypher is an unknown quantity at this point
I want to change my automatic tranny fluid this weekend. just wondering how much is needed for a basic change, not a total change. thanks
Old Mar 3, 2006
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
2.9 quarts of Honda ATF-Z1 for change, ~12 quarts to change for a full change. remember to change the atf only when the car is leveled. after draining, while refilling, fill in 2.5 quarts first, then use the dip stick to check levels, add more if needed. if the dip stick reads full, turn on the car and cycle the gears. turn off the car, then check the levels again. if the levels drop, ill add some more. now drive the car around the block, then check atf levels again. add more if you need to, but add in low increments. hope this helped
Old Mar 3, 2006
Cypher's Avatar
sound good thanks
chuffsy
May 16, 2015 03:52 PM
BootyDo
May 7, 2015 04:46 PM
markp94
Apr 30, 2015 09:19 PM
Herman49
Apr 29, 2015 01:22 PM
silverdevil
20
Jun 2, 2007 04:42 PM
