Need info for dealership not to screw me over(headlights out)
Old Jun 4, 2005
Seabass's Avatar
Seabass is an unknown quantity at this point
Hey everyone, ok I took my car in about 3 months ago for them to do the recall on the headlights, the one that makes the low beams from not working. So now my right side low beam doesnt work and the dealership says to me that its not a part of the recall and its something else. I have a lot of stuff on my car and they said its gonna be $77/hour and they dont know how long its going to take since I got so much **** on there. So i bitched at him and he said he will look at it on monday morning. So anyone know if the work they did on the headlights could have caused the right headlight to go out(low beam)? Thanks everyone
P.S. the high beam on the right side still works.
Old Jun 4, 2005
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
well, did you do something that might affect the low beams, like put in different bulbs? if not, then there is a good chance they did something wrong, or maybe they didnt take care of the recall.
Old Jun 4, 2005
C2i0v0i1C's Avatar
SuperMODrizd
if you havent screwed around with anything at all, and the car is still under warranty tell them to kiss of and they have to fix it
Old Jun 5, 2005
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
i thought for the recall, both low beams would go out. maybe your bulb is just busted, also its been 3 months, a lot could happen, take the bulb out to see if its the bulb or the car. dont want to spen $77 an hour to do something you couldve done yourself. also you could try another dealer.
Old Jun 5, 2005
i bet they messed up
Old Jun 5, 2005
PennyKnotOff's Avatar
Damn for $77/hour you could buy a new headlight
Old Jun 5, 2005
slicksivik's Avatar
its ur bulb probably, my bulbs went out in 3 monthes too. no biggy.
Old Jun 5, 2005
Al Gore FTW's Avatar
jdmtytedoridori
sounds like bulbs....take the one out, check it, and if you cant tell just buy a new sylvania stock replacement, they are like 5 dollars.
Old Jun 5, 2005
Seabass's Avatar
Actually tried 3 different bulbs....none of them turned on with the low beams.
Old Jun 5, 2005
Seabass's Avatar
...and checked fuses
Old Jun 5, 2005
CraigW's Avatar
I have some of the wiring info from a couple of sources, 02-03, PM with E-Mail and I will send them in PDF format to you.
Old Jun 5, 2005
streetglower's Avatar
look at a wiring diagram and start checking things. Look and see if the connecter for the bulb is melted. if it is ok, see if you have power at the headlight. If you dont, check and see if you have a ground. And go from there.
Old Jun 6, 2005
armjr2's Avatar
armjr2 is an unknown quantity at this point
yea thats what i would do, cuz if the dealer does it that the same thing they will do and charge u $77/hr too, and it would suck big time if its a fuse or something easy like that
GolNat
Suspension DIY
May 12, 2022 06:49 AM
paddystrang
May 18, 2015 09:56 PM
bo_red
May 4, 2015 01:47 PM
bsmiley
Apr 27, 2015 01:27 PM
NeoMagus
Nov 7, 2001 10:10 PM
