afraid to downshift
Old Apr 22, 2005
Silver_Si's Avatar
Silver_Si is an unknown quantity at this point
afraid to downshift
Just wondering, has anyone else experienced the problem of a "sticky shift" in first and second gears, especailly when downshifting? Is there a loose screw quick fix or what is the best remedy.
Thanks
Old Apr 22, 2005
Silver_Si's Avatar
anyone?
Old Apr 22, 2005
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
what do you mean by "sticky shift"? hard to get out of gear or to put it in gear?
Old Apr 22, 2005
MarylandEcstasy's Avatar
You cant spell CRAP without APC
MarylandEcstasy is an unknown quantity at this point
nope. maybe you should get a dc short throw adaptor.. we have really long throws imo
Old Apr 22, 2005
02SILVEREX's Avatar
02SILVEREX has a little shameless behaviour in the past
I had a problem with sticky shifts! Everyone thought I was . My car was still under warranty at the time. After taking it to the dealer, (the car was still there) I found a TSB on it. Then the dealer called. The ended up replacing the shifter assy. It seemed to work. Until I threw a short shifter on. The shifter assy. they put in is an updated part. You may want to take a look into doing that. The stickyness I am encountering is to no fault of my own. But knowing the differance of how the two feel..... I know my stickyness is not a problem.
Old Apr 22, 2005
flotsamm's Avatar
First gear I think has a lock where you cant downshift unless your under 10mph. Someone please correct me if I'm wrong. Other then that, I've only had a problem a couple of times where at a stop, I wasnt able to get into first gear. To remedy this all you do is shift to second gear first then dop it into first.
Old Apr 22, 2005
pbfoot's Avatar
i like the sticky icky.
Old Apr 22, 2005
fixeruper's Avatar
fixeruper is an unknown quantity at this point
never happen for me, but putting in reverse i have to force it in or put it in 4th and then reverse thats the only sh** that i have problems with, i dont think its serious though
Old Apr 22, 2005
Diver's Avatar
Diver is on a distinguished road
Im riding an 04 and it happens to me often....the lock might be why for 1st, never really payed attention to speed but will now, but its also happened enough times when I know I have been coasting/rolling under 10...my Car goes in this Saturday to Dealer for 10K check....going to have them look at it and see what they say.
Since I am an auto acronym noob, whats TSB?
Old Apr 22, 2005
NoFriends's Avatar
I like ruining your threads.
You can get into 1st must sooner then 10mph if you know what you are doing.
Old Apr 22, 2005
cubanmike26's Avatar
I've had the 1st gear sticky situation before too...sometimes when the car is idle it won't go into 1st or even 2nd, maybe it has to with th clutch as well. I've found that when driving one doen't have to press the clutch all the way in to shift to other gears, but that's not the case when the car is idle.
Old Apr 22, 2005
Zzyzx's Avatar
Autocross Junky
There is no lock on any transmission.... what you are dealing with is 1st gear and the collar that acuates between 1st and 2nd are spinning at such different speeds that the syncro cant compensate for it... so the collar cant attach to 1st, so no down shift. What you need to do is syncronize the RPM's between the Collar and the Gear in order to down shift, and thats accomplished by rev-matching.
Old Apr 22, 2005
mad_ox1's Avatar
mad_ox1 will become famous soon enough
Its definately the syncros. I believe there are 3 on 1st and 2nd, and only one on 3-5 and R. As for 2nd, just slow down your shift and you shuold be fine. I can't think of a time I've ever wanted to downshift into 1st while moving much. 2nd can do pretty much anything other than a hill start. Listen to the AutoX guys ^^^ (rev match)they usually know what they are tlaking about.
Old Apr 22, 2005
hookitup34's Avatar
hookitup34 is an unknown quantity at this point
yea thats happend to me also when i stop sometime then go to put i to 1st and it wont go.
Old Apr 22, 2005
Al Gore FTW's Avatar
jdmtytedoridori
yeah same thing happens to me all the time with reverse. i dont think its serious either
Old Apr 22, 2005
pnoyster2k1cvic's Avatar
Balut Eating Champ
i used to downshift alot before too... but i found out downshifting is bad for the tranny/engine... always use your brakes!
if you're having problem shifting to first while on idle, i think you just need to bleed your clutch... just my .05 coz I fix mine by bleeding it...
Old Apr 22, 2005
adnmoh1's Avatar
adnmoh1 will become famous soon enoughadnmoh1 will become famous soon enough
for had the same kind of problem with the gsr, checked my tranny fliuid found out i was running badly deposited fluids, causing sticky shifts, just did a fluid flush and running back to normal. probably gonna have to check some other stuff to make sure but so far so good.
Tyler93
Mar 20, 2016 09:03 PM
7thgensurvivor
33
Sep 5, 2015 08:20 PM
tommycanada
Sep 5, 2015 04:59 PM
Kcpowerhouse
Aug 25, 2015 01:15 PM
adamdrives
15
Aug 8, 2015 08:53 PM
