i need help on the dash trim
Old Jan 18, 2002
Unomyname's Avatar
Unomyname is an unknown quantity at this point
what all should i paint and how do i take all these things off...like the center console by the shifter ****
Old Jan 18, 2002
TopFuel's Avatar
Ultimate OG Member
TopFuel will become famous soon enough
sup...i just did mine...i experimented and messed around with stuff to figure things out. Alright first off there are two clips in the front of that whole center console part and there are two screws on the side in the rear you have to unscrew also. Then you can feel the center console is looser. After that remove the piece around the e-brake by just popping it out of the clips and bam you have that piece out(must take this piece out first because the e-brake is in the way so you cant pull out the whole console yet). Then just take out the whole center console piece. After its all out then unscrew the screws behind that console to take out the plastic piece around the shifter. Hope this helps any.
Old Jan 18, 2002
Unomyname's Avatar
how do i take things off like the air vents by the doors
Old Jan 19, 2002
TopFuel's Avatar
Ultimate OG Member
the air vents are easy...just push one the vent either up or down and put your fingers in there and PULL!!! and it'll come out
Old Jan 19, 2002
GTekCiViC's Avatar
GTekCiViC is an unknown quantity at this point
I paitned my air vents
Old Jan 19, 2002
BlueIce2001's Avatar
BlueIce2001 is an unknown quantity at this point
what kind of paint did yall use
i was told i had to wet sand everything and prime it and then paint
i knew i had to prime it but i didnt know about the wetsanding and did ur paint stick good
or did it start crackin ?????
Old Jan 19, 2002
Dmitri's Avatar
Dmitri is an unknown quantity at this point
How do I get the door handles off?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
cferry7
Oct 18, 2015 06:32 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
frank_kleng
Sep 29, 2015 10:55 PM
