I got a 2.25 inch downpipe... Should I...
Old Apr 14, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
Should I use it... or wait for turbo. Would it do much on an NA setup?
Old Apr 14, 2005
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
na set up = minimal gains with any bolt on
Old Apr 14, 2005
Blahman2's Avatar
so... the question still stands... should I install? Or no?
Old Apr 14, 2005
diskreet's Avatar
If anything you will probably lose low end torque with the decrease in backpressure. so I would say maybe not. Put it on and see if you like. If not you can remove it and I am assuming its not too hard to do from anyone who told me about doing it.
Old Apr 14, 2005
Blahman2's Avatar
well... the problem is... a flange needs to be welded to one end. So it can connect to the cat.
Old Apr 14, 2005
Vantage's Avatar
Vantage should not be trusted
only put it on if u have a header, and 2.25" exhaust, otherwise its useless.
Old Apr 14, 2005
Blahman2's Avatar
I have a header and a 2.25 exhaust... So if I install it... I'll gain power?
Old Apr 14, 2005
Vantage's Avatar
IF u have an EX, i would install it. 2.25" should give u better top end, but ull lose some LOW RPM power, but most Vtec guys want to take advantage of top end, where most non-vtec guys take advantage of Low end... all depends wat u want.
Old Apr 15, 2005
Blahman2's Avatar
I want to take advantage of low end power... I have vtec... but its garbage on out engines.
Old Apr 15, 2005
jttegx's Avatar
OMNES AD UNUM
i say install it. 2.25" isnt that huge compared to 2.5
2.25" is ideal for N/A setups
Old Apr 15, 2005
Vantage's Avatar
2.5" is WAY to big for a 1.7L SOHC, i would probably stick 2.5" on a bully built B18c1, or b18c5, but NEVER any SOHC, or anything smaller than a 1.8L.
Anyway, your engine is more made for top end performance, hence the Vtec head, so i think the 2.25" would be smart, but thats just me.
Tedverseti
Apr 23, 2020 01:45 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Tedverseti
Sep 29, 2015 05:41 PM
Islesfan
Sep 29, 2015 03:42 AM
