i need experienced help.
Old Jan 7, 2002
alexxx's Avatar
alexxx is an unknown quantity at this point
ok since it's a new car.. it needs new setup for drag racing. i have an auto ex. why auto? because my mom drives it. i dont need turbo because im not a race a holic. i need NITROUS. other than that i need some go power for my civic. ne set up suggestions? like i said experienced so all u wannabe street racers shut up. personally this is my first civic. before.. i had a s13 silvia conversion. i ran turbo and nitrous. the motor was already powerful but the boost made it win more. so guys, i need a list of most important shist to go fast on a quarter mile. for now no internal engine mods.
Old Jan 7, 2002
ricerocket's Avatar
ricerocket is an unknown quantity at this point
hey u r that guy pumpin the yellow s14 in quuens? i have a yellow eclipse with white rims i think i raced u on Francis Lewis blvd last month. well anyways back to the 2k1 ...well since the 2k1 ia a n/a car there isn't much u can do intake, header and exhaust will only give u around 8-10hps max...since u have v-tec u can get a vtech controller to get your v-tec to come on early (lower the rpm where the v-tec kicks in) and those $hits look cool. then u can change your cams later on those help 2..but a lot of work. like u said jsut get the NOS that will fix everything....what if your mom uses the NOS by mistake while she is driving...
Old Jan 7, 2002
briaros6's Avatar
briaros6 is an unknown quantity at this point
I don't want to come off sounding mean or anything but honestly is this a joke? The 7th gen civic for drag purposes isn't the best selection, an auto only compounds the problem, and you're just wanting NOS? Straight from the Honda website a 2002 EX model only produces 127hp@6300RPM add NOS to that and you're looking at anywhere from 25hp and up, but when you go up you'll have to reinforce the engine to handle anything over about 200hp. To be effective in drag racing even if it's on the weekends you'll need 200+hp at the wheels to win decently. MIND you I said win decently because there are drivers who can win running just stock if they're that good and the other guy is that bad. If you're also dragging multiple times in a day and you're using NOS each run your engine is going to blow a hundred times faster than normal usage. Remember you're amplifying the explosion process in the engine and that's putting excess pressure on the block which is designed to handle only so much pressure for a certian amount of time. If that's not enough you're also putting NOS into an automatic transmission. Automatic's are set up to change gears based upon an internal regulator, by kicking NOS into the system there's a chance you can blow the regulator and can set the planetary gear out of synch. It's pretty unlikely but there are times where it has happened and it's also very expensive to replace an automatic transmission.
So, in conclusion go buy back your silvia and keep racing that...
Old Jan 7, 2002
2k2civic's Avatar
I would probably get a custom turbo kit that'll pump about 6-9 psi (something small) and run nitrous right alongside the turbo. Also, get pulleys, cam, cam gear, titanium valve springs, update ignition coils, iridium spark plugs, new fuel pump and fuel pressure regulator, intake, exhaust, headers, high flow cat, upgraded torque converter, and thats about it.
Ya, it sounds like a lot, but that's what your gonna need if you really wanna drag.
Old Jan 7, 2002
ricerocket's Avatar
brairos wut u are saying is true...but isn't there a guy on this site with a lx auto that has NOS in it? he also got the greddy exhaust (cause he took a huge @ss pic of his muffler telling every 1 letting everybody no its a greddy)
Old Jan 7, 2002
briaros6's Avatar
how many runs does he make a day? if you're using for say just one pass then fine have at it, but if you're wanting to compete at an amateur level let's say you're talking 5-8 runs in one day and you're doing that 4 times a month think how much stress the engine takes in that month. Many people only think short term, but it's the long term that will get you.
Oh and also depending on where you live the size of your NOS can get you a nice traffic ticket too if you're caught with it in the vehicle at the time of being pulled over regardless if it's hooked up or not.
Old Jan 7, 2002
ricerocket's Avatar
true...but i dun see the point to use it to pass a car ( depends wut kinda car it is) if its a turbo charged u will pass them but they will pass u in a few seconds when the turbo kicks in so...it really depends who u are messing with
Old Jan 7, 2002
racinginindy's Avatar
racinginindy is an unknown quantity at this point
Not to sound rude, but is your mommy going to let you put NOS on her car? I think she will notice!![IMG]i/expressions/face-icon-small-tongue.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jan 7, 2002
KurupTLX's Avatar
KurupTLX is an unknown quantity at this point
I've heard NOS actually worked better on autos.... weird
K-lx
Old Jan 7, 2002
alexxx's Avatar
like i said... experienced help.. thanks for responses.. but now the part we all missed.. im only gonna do joy runs in the bronx so under 200 im ok with.. i just want the most boost power on our car in a quarter mile.. injen cold or ram? header or stock? exhaust or just change the muffler. tighten cable or leave it.. cuz i got one big advantage.. my car is already lighter than stock.. like i mean i pulled a lot of shist out.. list people pls..
Old Jan 7, 2002
briaros6's Avatar
for joy rides okay here you go on an auto EX a RAM intake shows a higher gain, headers will always help, as for exhaust it's a little gain but not much so it's up to you, and tighten the cable if you want. Just remember these are new on the racing market so not everything has been fully tested so don't ask how much specific gain because quite honestly you'll get fifty different answers. Also if you're spending this much money go ahead and get the Jet reprogram on the ECU to handle all the upgrades after you make them.
Old Jan 8, 2002
2k2civic's Avatar
Trying to get custom turbo
Old Jan 8, 2002
LexBoy's Avatar
LexBoy is an unknown quantity at this point
interesting how he used to do all those turbos and mods and modified his car to a s13 silvia
but he doesnt know what to get for his new civic
oh by the way
you are the only wanna be racer and shietz
stupid f uck
Old Jan 8, 2002
Swifty's Avatar
From: Ricemond B.C. Canada, British Columbia, Canada
Swifty is an unknown quantity at this point
<< interesting how he used to do all those turbos and mods and modified his car to a s13 silvia
oh by the way
stupid f uck
be nice to the guy, not all newbeeeeessss know they are DUMBA$$ES
Old Jan 8, 2002
alexxx's Avatar
i see you like to criticize and instigate.. good
Old Jan 8, 2002
alexxx's Avatar
oh i see so you want to be cool like him too.. good job
Old Jan 8, 2002
CiviCKiD's Avatar
CiviCKiD is an unknown quantity at this point
Ur just dumb for gettin rid of the conversion and gettin a ex....thats just my opinion...take it or leave it...i dont care
Old Jan 8, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
yea better ask mommy before you get that NOS put in....even with NOS the 7th gen Civic, especially Automatic, will get dispatched by even the most stock imports on the road --
and bottlefed is the member with the LX and NOS
Old Jan 9, 2002
Swifty's Avatar
<< i see you like to criticize and instigate.. good >>
<< oh i see so you want to be cool like him too.. good job >>
Listen you dumb ****...if you had the knowledge you think you do from your past wet dreams....oops I mean past ride that you put together with some hot glue and sheet metal screws, with your turbo and Nitrous you wouldnt be asking these questions....Am I right...Shut up I wasnt asking you....Of course I'm right.....So leave the Nitrous alone or your mommy will be pissed you modded her car, and stop wasting everyones time.....u want a flame war...bring it on...and i'll make you my B!tch
<< i dont need a turbo because i'm not a race a holic >>
<< , i need a list of most important shist to go fast on a quarter mile >>
These are from your post...so make up your mind...are you a Racer or Not
DumbA$$[IMG]i/expressions/moon.gif[/IMG]
Old Jan 9, 2002
Boosted's Avatar
Boosted is an unknown quantity at this point
I have NOS and I am an Auto LX!!!!
Click Here For Full Details On My Car
Old Jan 7, 2004
Looney_01Civic's Avatar
Looney_01Civic is an unknown quantity at this point
240 to Auto EX = Stupid!!!!
Nissan to Honda Even more stupid!!!
Old Jan 7, 2004
VTECTypeR's Avatar
omg this is such a old thread 2 years old!!!
Old Jan 7, 2004
robbclark1's Avatar
Retired suspension supermod.
why bring back this thread?!?! gosh
ken4444
Sep 30, 2015 07:37 PM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
Islesfan
Sep 29, 2015 03:42 AM
C-Hamm
Sep 28, 2015 10:31 PM
