I hate VTEC.....kinda
Lol to the freeway vtec. Yeah when I'm cruising at 65mph the vtec is off. Then I push the gas a bit and vtec light comes on and stays on, but there's absolutely no difference at all!
Originally Posted by EternalBlue_Vic
I think the civic hybrid gets rwhp. Only because it has a electric motor running the passenger rear wheel, along with it's inline 4 for the front. Am i right? Not Vtec though
You can vary the timing of the events by advancing or retarding the camshaft, which will improve bottom or top end power, depending on which way you move the cam.
But then again, you can't have it both ways. Getting power and performance at low AND high revs is impossible - unless you could somehow vary the cam's timing and lift based on engine speed.
And its really not a big deal... ricers need to stop "Vtec"ing all over the place. Most cars have similar technology to this now... if not better!
Damn 5 pages later, and it's still going? All I know is that Honda created V-TEC in order to improve fuel consumption and emissions.
It's like I've said before, the car basically drives around on fuel efficient mode, until the ECU senses increased throttle and engages V-TEC. I'm sure you guys all saw this on www.howstuffworks.com but it doesn't explain the reason that Honda used it was to save gas and environment.
That's what Honda, to the average consumer, is about. ECONOMY.
yeah
Originally Posted by mrchowmein
the first honda car to have vtec was the NSX. it was used to gain more high end hp and low end torque. since then there have been many variants of the vtec system such as dohc vtec, sohc vtec, vtec-e, ivtec and so on. each verison had a different application. DOHC VTEC has been used in the past as the performace verison of vtec, while IVTEC application is similar to continous variable valve timing system of other car companies which allows the car both gains fuel efficiency and power. sooo... Honda didnt exactly used the vtec system to simply save gas and the environment, there are other applications of vtec.
and on our car I believe it is for fuel efficiency
before i close this old *** thread.
the purpose of standard vtec is not JUST fuel economy. it's a balance of fuel economy and performance.
vtec offers the fuel economy of a low rev, conservative cam profile, with the better power delivery of a more aggressive top end cam profile.
some instances, like the EX are not as aggressive as say, the S2000 or NSX.
JetsterDajet
52
May 8, 2016 12:11 AM
jzhartman
22
Jul 23, 2015 10:42 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
