Supercharged Turbo STi
Old Jun 13, 2004
  #31
criminal's Avatar
criminal is an unknown quantity at this point
its called a bicharger system...i know a guy who had a 6th gen hatch with a bicharger setup on it running high 9s
Old Jun 13, 2004
  #32
sCoTtEh's Avatar
sCoTtEh is an unknown quantity at this point
hrmm..i wonder if it would work w/ our civics...
Old Jun 14, 2004
  #33
LiKEaFeRiO's Avatar
Forced Air Technologies project STI
AMG supercharger
Garrett turbo
Was running at 8lbs of boost on the S/C and 12lbs on the T/C before an I/C was fitted on.
Thread is here:
http://forums.s2ki.com/forums/showth...hreadid=211040
Old Jun 14, 2004
  #34
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
You can supercharge and turbo charge a vehicle.. a supercharger works off your intake and a turbo works off your exhaust..
If i'm not mistaken the miguiars car is Turbo/Supercharged.. It couldwork with our civics if we had 1) a supercharger 2) the internals strong enough to withhold that amount of power.
Old Jun 14, 2004
  #35
Titleist71's Avatar
i bet he goes thru a 1/2 tank of gas just starting the damn thing. gas $$ vs. that set up is questionable however very awesome indeed.
Old Jun 14, 2004
  #36
AzNmiKex215's Avatar
2k1civic.com O. G.
Originally Posted by RiceRocketeer
You can supercharger and turbo charge a vehicle.. a supercharger works off your intake and a turbo works off your exhaust..
Ummm i beleive a supercharger is run off the crank pulley. its connected to the pulley via a belt which spins the supercharger.
Old Jun 14, 2004
  #37
gelshmoff's Avatar
gelshmoff is an unknown quantity at this point
Someone brought up an interesting point on likeaferio's link:
Well wouldn't a nitrous system accomplish the same without parasitic drag of the supercharger?
If you're going to go through all that, wouldn't nitrous be better?
Originally Posted by LiKEaFeRiO
Old Jun 14, 2004
  #38
carbonrevo's Avatar
carbonrevo has a little shameless behaviour in the past
Our engine will blow after 5 min of driving w/ stock internals.
Old Jun 14, 2004
  #39
blkdak99rt's Avatar
Riceburners Bitch
blkdak99rt is an unknown quantity at this point
alot of what is going on with the "bicharger" systems is that the advantages of the supercharger is that you have the power from idle because it runs off the serpentine belt/ crank pully belts and the turbo is there to recycle the exhaust fumes which is said to be a more power efficient method..... whatever i just think its to much money for to little benifit
Old Jun 16, 2004
  #40
urbanwarfare2k2's Avatar
urbanwarfare2k2 is an unknown quantity at this point
wow....dats amazing
Old Jun 17, 2004
  #41
Satin-EX
Guest
Posts: n/a
Turbo/SC combo
I think the Navy's LCM use 2-stroke diesel (RayMarine) with that sort of combo: it's turbo -> SC -> engine, so the SC is fed cold air fr. the Turbo. It also uses the twin-screw type SC just like in the photo.
Old Jun 17, 2004
  #42
CdnSilverStreak's Avatar
Historic Member
CdnSilverStreak is a glorious beacon of lightCdnSilverStreak is a glorious beacon of lightCdnSilverStreak is a glorious beacon of lightCdnSilverStreak is a glorious beacon of lightCdnSilverStreak is a glorious beacon of lightCdnSilverStreak is a glorious beacon of light
Cool, the ride must be incredibly fun too...
Old Aug 4, 2004
  #43
ShoelessEX's Avatar
The wheel is turning...but the hamster is dead
ShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to all
sweeeeeeeet *drooling*
Old Aug 4, 2004
  #44
Changu-San's Avatar
Mr. Clean
thats something new...i think itll be cheaper if he just got n2o for low-midrange...
Old Aug 4, 2004
  #45
jfan's Avatar
Yep, I remember first seeing that on the Team Meguiar's Type-R, it was putting down like around 450 horsepower I believe.
Old Aug 4, 2004
  #46
acidbaby's Avatar
The Beez Kneez
why is everyone questioning the reason behind it? wtf who cares? that is some crazy wrenching.
Old Aug 4, 2004
  #47
acidbaby's Avatar
The Beez Kneez
Originally Posted by blkdak99rt
or this one i was wanting to post it..... twin turbo superchargered!!
holy **** you cant even see out of the window
Old Aug 4, 2004
  #48
Jai's Avatar
Jai
Jai is an unknown quantity at this point
what.
the.
Old Aug 4, 2004
  #49
AR's Avatar
AR
e-married to daydreamer
Hot Damn!
Old Aug 4, 2004
  #50
SeThisBlaze's Avatar
SeThisBlaze is an unknown quantity at this point
Its Been Done Before...I remember way back when...HKS had a superchanged & turbo interga
Old Aug 4, 2004
  #51
xtreme26's Avatar
xtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura about
i always knew this was possible
Old Aug 5, 2004
  #52
Changu-San's Avatar
Mr. Clean
imma go ask my physics proffessor...j/k
Old Aug 5, 2004
  #53
DodgeNeonSRT-4's Avatar
DodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of light
yes a bicharger system is very possible on a civic and would actually be quite easy if judging by the amount of space under the hood of a 2003 Civic EX (the car I am familiar with). after the stock intake setup is removed it would be very spacious, just have to change up the internals. all forged would be needed, but honda makes very solid blocks so that would not be a problem.
the 8psi, 12psi setup...yeah that sounds about right...for a track only application you might be able to push that to at most 10, 15-16.
you're right, it does make sick power, blower on the low end and turbo on the high end. the blower on the low end also allows the turbo to have a big fan (bigger the fan, longer it takes to spool but more power it makes on the high end)
this system is also called a whipplecharged system
we had one of these last year at school during our F5 racing competition...a blown, turbocharged, nitrous, fuel injected two cylinder honda motorcycle engine puts out good power...too bad we never had time to dyno it. we kept the block and just replaced internals, got the traction to back the power, retarded ignition, etc.
made sick power, I wish we had a dyno available...I will make that suggestion for next year
Old Aug 5, 2004
  #54
nitrous at low-midrange...that would require forged internals as well, so I don't see it being much cheaper...less powerful anyway
and nitrous in low gears...if your piston rings and intake manifold had hands, they would be strangling you for suggesting that
by the way, the bicharged setup actually gets scary good gas mileage...it is pretty obvious that any car makes its best efficiency in the high gears and turbos notoriously help that efficiency...the blower helps slightly as well but gets it into those high gears quick...with a setup like this though you are running 103 octane racing gas + octane booster anyway so although you may get 50 miles to the gallon, each gallon costs a boatload
Old Aug 6, 2004
  #55
white2K2EX's Avatar
I sure wish my car was newer
My friend got a ticket for an "obstructed view" because he had his girlfriend's graduation tassel hanging from his rearview mirror. I'd had to see what kind of tickets that would get.
Old Aug 7, 2004
  #56
I got a ticket for that too...I thought that was just some BS the cop was shoving up mine.
Damn cops. Who wastes their time pulling someone over on the Turnpike for a graduation tassle when there are guys flying by me at 95 in a 65 double penalty zone...
It's because I'm a young white driver...good looking car I must be street racing. ::rolls eyes at retard cops::
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
tomas6791
Sep 11, 2015 06:47 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
justcruzin125
Aug 11, 2015 09:09 PM
