tranny oil
Old Apr 21, 2004
  #31
Lucid484's Avatar
Lucid484 is an unknown quantity at this point
Yeah my Auto tranny took 3 quarts too...Considering that in the manual it states that it takes 2.9 quarts.
Old Apr 21, 2004
  #32
deciuss's Avatar
Boosted Auto
if you want a cheep way to get it in just take off your intake take a water bottle cut the bottem off the part that you drink from put that into where you put the fulid and then pore it in like a funle worked perfect.
Old Apr 21, 2004
  #33
yourinmyw0rld's Avatar
which one should i get the redline 75w/80w manual or manual 90w synthetic
Old Apr 21, 2004
  #34
03white5spd4d's Avatar
03white5spd4d is an unknown quantity at this point
75w/80w, the bottle should have a big MTL on it. if you go through summit racing the part number is "RED - 50204"...its usually 7.99/ quart but its on sale for 6.45/quart there is a haz-mat fee so take that into account, but i use summit alot and they are good
Old Apr 22, 2004
  #35
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
im going with the royal purple, but i heard both r great. also know a couple of honda guru's who run 10w-30 motor oil in there mt. they say it holds up and makes shifting a breeze. but there on older hondas.
Old May 24, 2004
  #36
reddawnman's Avatar
reddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to all
I'm going to put redline in my tranny in a couple weeks. From the response both here and at the http://www.bobistheoilguy.com boards, the stuff works great for cooler climates and for racers, but "daily driving," grandmas might not dig it, because people were saying the shifts felt different.... ymmv.
If you change the MTL yourself, yeah, get the redline MTL, the light "Honda acura" stuff, and undo the filler bolt first, THEN the drain bolt. Always nice to be sure you can fill it before you drain it :-)
good luck.
May 4, 2016 07:14 AM
brags
46
Jan 7, 2016 09:39 PM
jessica19699
Jul 29, 2015 05:51 AM
beeemerdude
Jul 23, 2015 03:53 PM
Kyle Cargazm
Jul 16, 2015 02:06 PM
