tranny oil
Old Apr 18, 2004
Quijano187's Avatar
The Evil Genius
Quijano187 is on a distinguished road
tranny oil
JUat went to jiffy lube and i get a tranny oil change and they told me they dont have the right type of oil.. THey told me its a type gls oil or somthing. Wwnt to autozone and asked them about it and they told me it takes normal 5 30 or something... DOES ANYBODY KNOW WHAT type OF TRANSMISSION OIL GOES IN A 2001 CIVIC EX MANUL ? PLEASE SOMEBODY LET ME KNOW THANKS.
Old Apr 18, 2004
GreenNVicious's Avatar
Newbie
Honda OEM tranny fluid
Old Apr 18, 2004
Just go get the honda fluid from your dealership. I did that for my auto, but I imagine they would have manual fluid as well.
Old Apr 18, 2004
Quijano187's Avatar
The Evil Genius
yea but i dont want to go honda cause they charge so much.. DOes anybody know what type oil or what kind ? thanks alot everybody for helping
Old Apr 18, 2004
Newbie
Dont be a cheap *** and put junk into your car, if you're going to change it, do it right. You might as well not change it if you're going to throw in some crap from Pep Boys
Old Apr 18, 2004
Quijano187's Avatar
The Evil Genius
is that im not trying to be cheap im trying to as a additive to the tranny oil ( lucas tanny oil) and honda wont let me do this there. Maybe i just go to honda a get the tranny oil there and go somewhere else to do the tranny oil change with the lucal oil.. that is the reason why i want to know what kind of tranny oil is used in my car .. you guys are right .. any here using any different type of tranny oil.? thanks green and gearbox
Old Apr 18, 2004
Newbie
oh additives? dont use that crap, no oil or fluids need extra additives, they come made with additives already in there. believe me, it isnt going to do anything by adding Lucas Oil...now I know what you're talking about. Save yourself the $$ and return it and just use 100% OEM tranny fluid and your set
Old Apr 18, 2004
Quijano187's Avatar
The Evil Genius
aight man thanks
Old Apr 18, 2004
Newbie
No prob imp:
Old Apr 18, 2004
Quijano187's Avatar
The Evil Genius
is pensoil full sysntheic any good.. thats what i got today with lucas... im telling you it fells smoother than my other recent oil changes. When i i didnt use lucas i felt the ride kind of sluggish sometimes. I still like lucas oil.
Old Apr 18, 2004
Newbie
full synthetic=mobil 1, hands down
Old Apr 18, 2004
Quijano187's Avatar
The Evil Genius
thanks again .. iwll use mobil 1 full synthetic next time with lucas next time.. thanks..
Old Apr 19, 2004
yourinmyw0rld's Avatar
can i use Royal Purple SynchroMax ManualTrans and how many Quarts do we need????????
Old Apr 19, 2004
rckdrmr's Avatar
rckdrmr is on a distinguished road
exactly. is it worth it to pay a little more to have it done right... or save a few bucks and have some problems down the line?
Old Apr 19, 2004
Elite's Avatar
Elite is an unknown quantity at this point
redline mtl is the best, i've heard. 7.64 a quart though and our trannies need 2.5 quarts
Old Apr 19, 2004
sjoback's Avatar
sjoback is an unknown quantity at this point
you only need 2 bottles
d17 trans uses less than 2qt. like 1.8-1.9
Old Apr 19, 2004
Quijano187's Avatar
The Evil Genius
thankyou
Old Apr 20, 2004
03white5spd4d's Avatar
03white5spd4d is an unknown quantity at this point
^^^^ i agree. as for 2.5 quarts..that wrong, its 1.5liter (1.6 quart) for fluid changes on manuals and 2.7liter(2.9quart) for autos
Old Apr 20, 2004
when can i get the redline mtl??? can i get that at a local hardware store?
Old Apr 20, 2004
^^^^^^summit racing online. they do free shipping, but dont know if there is a minimum you got to spend
Old Apr 20, 2004
usafstud's Avatar
i'm putting in redline MTL tranny fluid on my car since i race it
its point less if u just drive ur car around town to get redline
Old Apr 20, 2004
then i'm getting reline mtl then
Old Apr 20, 2004
deciuss's Avatar
Boosted Auto
my a/t took 3 quarts srug....
Old Apr 20, 2004
when u were filling it, did you have the car raised. when filling, the car should be on the flat, even ground and you should stop filling when in starts coming out the fill hole.
Old Apr 21, 2004
Quijano187's Avatar
The Evil Genius
word.. how do you change your tranny oil.. been spending alot of cash lately ... does anybody know hows it done?
Old Apr 21, 2004
the a diy thread just search, basically jack the car up and look for a recessed (i guess thats what it would be called) square, and indent where a 3/8" ratchet would fit with no socket. loosen that up and drain, then close properly and open the fill bolt. put the car on leve ground and fill till tranny fluid comes out of the fill bolt. if fill bolt has crush washer replace, i dont know as i havent done it yet. i dont have the torque specs, i have the factory service manual in the garage (<<<<jeez is that thing huge). b4 u drain, make sure you can 1.)loosen the fill bolt and 2.)get fluid to it, a hand pump is ideal.
Old Apr 21, 2004
deciuss's Avatar
Boosted Auto
i filled it on flat ground and when i was done it showed it between the 2 little dots its supost to be inbetween i also chexed it a week latter to make sure and it was fine.
Old Apr 21, 2004
what two little dots??
Old Apr 21, 2004
Quijano187's Avatar
The Evil Genius
i need a hand pump?
Old Apr 21, 2004
Originally posted by Quijano187
i need a hand pump?
no you dont need one but it will make fill it up alot easier. you put it one end into a container of tranny fluid, and run a small hose to the fill hole. when the fluid starts coming out the fill your done, it the easiest way i know of.
