when do you shift??
Old Dec 6, 2003
  #31
Elite's Avatar
Elite is an unknown quantity at this point
Originally posted by Yukonart
For economy I usually shift around 4k
Keeps you out of VTEC (if so-equipped) but keeps your RPMs high enough to keep from lagging. That is, unless you're going uphill.
We have stage 2 vtec which engages depending how hard you push the gas pedal i'd say you take that back
Old Dec 6, 2003
  #32
shmeb's Avatar
shmeb is an unknown quantity at this point
3-4k.
Old Dec 7, 2003
  #33
Boilermaker1's Avatar
Jap-Euro Fusion
Originally posted by ceddy
how bout racing ??? from a dead stop i drop the clutch at 2.5k and shift at exactly redline?? where do u guys shift when u race?
My standard autocross launch is 3700 RPM. I get 10-15 feet before I hit the timing lights, so its wise to have the revs as high as possible when you hit them ( stupid torqueless engine). I don't drop it, just feather it off... figure they spin for 5 or so feet and I hit the lights about 3500-4K RPM if I get away clean. In the rare event that the first straight is long enough to redline out, I usually don't anyways.... max HP is 6100, max TQ is 5500. Shifting at 6100 drops the revs to about 5300, I'll usually go by sound anyways... The intake resonates at 6000, so I'll shift about a second after I hear the sound change (its about 6400)
Driving normal.. I shift when ever I feel like it. The better the mood, the higher I usually go, but no higher than 4500 usually. Just lollygaging in traffic... maybe 3500.
Old Dec 7, 2003
  #34
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
SHIFT AT HALF OF UR RED LINE
like if u have 7000k red line shift at 3500 and so on
Old Dec 7, 2003
  #35
SeCosCiV's Avatar
Pimp Juice Distributor
From: Dallas, Tx but now Virginia Beach, VA 'cause of job...
SeCosCiV is an unknown quantity at this point
I dont shift, Honda does it for me so I'm assuming everthings being taken care of...
Old Dec 7, 2003
  #36
edicivic2k1's Avatar
edicivic2k1 is an unknown quantity at this point
i got auto, so i only down shift in snow.
Old Dec 7, 2003
  #37
X-R8ED's Avatar
X-R8ED is an unknown quantity at this point
Elite is right my VTEC light comes on at 2600 in 1st,2nd,3rd,4th and 2500 in 5th when Im flooring it. Si/Ex 5spd.
Old Dec 7, 2003
  #38
MORG655's Avatar
MORG655 is on a distinguished road
I shift when smoke starts to come out of the engine. Well not right away. Only once I can smell it. Before you can smell it, it's not that bad. Around 9000rpm or so I guess.
Old Dec 7, 2003
  #39
killah99si's Avatar
killah99si is an unknown quantity at this point
shift before 5600 rpm vtec kicks in mixed with the boost and them damn wheels start spinning if I don't shift.
Old Dec 7, 2003
  #40
tripledoublegs's Avatar
Euro-Spec
Originally posted by FALKEN
3000-3500
same here
plus I save some gas
Old Dec 7, 2003
  #41
civic01vtec's Avatar
for just driving around i usually shift around 3.5k and if i am merging into traffic off an on-ramp or sumtin similar then i will usually shift around 4,300-4,500........there is no reason to go over that unless ur are racing.
Old Dec 7, 2003
  #42
civicskater's Avatar
Chicks dig my scent
^^^Same here, the only time i shift at 5-6.5K is if im racing, or i want to hear my intake(the first week i had it on i did it 3 times)
Old Dec 9, 2003
  #43
KpFeVeR03's Avatar
KpFeVeR03 is an unknown quantity at this point
If you look in the owners manuel it tells you when the recomended shift times are
Old Dec 9, 2003
  #44
Mikeds122's Avatar
Mikeds122 is an unknown quantity at this point
Usually 3500 for economy purposes.
Shift points vary with different cars - A car with a bigger engine and a lower redline (prob longer gears) can obviously shift a lot lower because it will get the same power at much lower rpm. Our cars have zilch as far as low end power and a fairly short first gear, so we have to leave it in gear until a higher rpm in order to get moving.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Jrosa
Sep 14, 2015 08:24 PM
