Cadillac 16 specs
Old Aug 20, 2003
Validus's Avatar
Validus is an unknown quantity at this point
Cadillac 16 specs
YES i know the sixteen has been posted about before on here. But look at these specs
http://www.cadillac.com/cadillacjsp/...ecs.html#power
Overview
Body/chassis structure: spaceframe
Body Material: aluminum
Chassis Material: aluminum / steel
Suspension: Front: Sigma-based high arm SLA
Rear: semi-trailing arm, 4-wheel steer
Wheels: 24" x 9" aluminum
Tires Size: Front: P265/40R24
Rear: P265/40R24
Tires: Michelin custom tread
Brakes: Baer 6-piston, 16" rotors
Back to top
Powertrain
Engine: GM 16-cylinder, 90-degree
Engine displacement (cu. in / cc): 830 / 13600
Horsepower maximum (hp / kw): 1000 / 745
Torque maximum (lbs-ft / Nm): 1000 / 1355
Transmission: modified Hydra-Matic 4L85-E
Back to top
Dimensions
Height: 54.8 / 1392
Length: 223.3 / 5673
Width: 79.9 / 2029
Wheelbase: 140 / 3556
Track: Front/rear (in / mm): 69.5 / 1766
Weight: 5000 / 2270 (estimated)
I mean yeah it weighs 5000 pounds, but do you really care? I dont :P
I get magazines from cadillac. Latest news is that the car is a production possibility, it would come with a limiter that would only use 8 cylinders during most driving conditions.
MMmmm think about after you get that car, just rechip it and you have 1000 hp and 1000 tq! Then slap on a twin turbo......
I think this car proves that technology can only get you so far, but in the end displacement will bring you to the top.
I mean look at it. imp: imp:
Old Aug 20, 2003
Validus's Avatar
you know you want it
Old Aug 20, 2003
NoFriends's Avatar
I like ruining your threads.
fugly...
Old Aug 20, 2003
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
Originally posted by NoFriends
fugly...
I disagree. It's a piece of art.
Old Aug 20, 2003
NoFriends's Avatar
how much are they supposed to go for anyway?
Old Aug 20, 2003
Validus's Avatar
I'd estimate somewhere around at least 100k probably morel lik 125k.
Elciteeve
Sep 28, 2015 12:40 PM
pilebuck13
Sep 21, 2015 10:45 PM
AffliictiioN
Sep 16, 2015 02:21 PM
fvckbg
Sep 8, 2015 09:55 PM
