General 8th & 9th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
EPS warning disappears when engine turned on
Old Dec 30, 2018
peeks's Avatar
peeks is an unknown quantity at this point
Hello,
I recently bought a used 2015 Civic LX Sedan (automatic) after retiring my 2002 civic. I have noticed that when the I turn the key to the accessory position, my dashboard lights up as usual and I also have an amber EPS (Electronic Power Steering) warning (along with the ECO symbol and the parking brake symbol). But it disappears when I turn the engine on and the steering feel is normal like other 2015 Civics which I test drove.
The user manual doesn't explicitly mention if this warning could be posted when the engine (and power steering) are not on. For sure, the power steering isn't (and shouldn't be) working but should I constantly have an EPS warning until the engine is turned on? Should I have the vehicle checked out even if the warning disappears with the engine on?
Thanks so much!
Last edited by peeks; Dec 30, 2018 at 08:00 PM. Reason: added definition of EPS acronym
Old Dec 31, 2018
Colin42's Avatar
Re: EPS warning disappears when engine turned on
It's normal, it will be on until the engine is running like the battery light, oil pressure, check engine, etc.
Old Dec 31, 2018
Mikeyyy's Avatar
Mikeyyy is an unknown quantity at this point
If it stayed on then you'd need to worry.
Check your owners manual...
Old Jan 1, 2019
peeks's Avatar
Thanks for the responses. So it seems like this is normal and expected behaviour after all!
macmax2018
Apr 9, 2018 11:52 AM
dkablack
Mar 21, 2013 11:52 AM
aznboysrfr
Oct 17, 2004 02:59 AM
HeRbaLuS
Mar 1, 2002 08:38 AM
