General 8th & 9th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Bluetooth music problem
Old Oct 28, 2018
MoffettLeslie's Avatar
MoffettLeslie is an unknown quantity at this point
I just recently got a new iPhone (XS max). I paired it with my bluetooth in my 2014 Civic and the phone works perfectly. However, When I switch to bluetooth to play songs, the screen flashes each song title and goes through the whole list. It will not play any of my music (which worked perfectly with my prior iPhone). I know I have it paired correctly because I can use the phone and connect the bluetooth to my music library. However, as I noted above, nothing plays, it just flashes each song title on the screen in quick succession. Any help would be greatly appreciated. This is so frustrating.
Thank you
Old Oct 28, 2018
Re: Bluetooth music problem
Check if phone is actually compatible, not all phones and features work as desired: http://handsfreelink.com/honda
Try it using the cable instead of bluetooth?
Old Oct 28, 2018
GolNat's Avatar
Prelude Owner
Have you tired deleting all previously paired phones from the car and then re pairing the XS? Also reboot the phone as it may be an app issue seeing as the phone feature works.
Old Jan 4, 2019
Meanie's Avatar
Meanie is an unknown quantity at this point
Close the music app, restart the phone then reopen the music after phone restarted.
Jpownell
Sep 3, 2021 09:57 AM
mrcivic1
May 20, 2018 02:32 PM
soulhon
May 12, 2017 10:14 AM
invinciblegod
Bluetooth
May 7, 2017 04:11 PM
Meanie
May 12, 2016 07:39 PM
