honda civic 2017 horn goes off when turning the wheel
Rep Power: 0 honda civic 2017 horn goes off when turning the wheel
I recently bought a salvage honda civic 2017 and noticed the car honks every time I make a turn. Sometimes it makes a lot of small honks and sometimes one loud honk. How can I fix this or make it stop?
Received 1,126 Likes
Rep Power: 191 Re: honda civic 2017 horn goes off when turning the wheel
Could be the clock spring is bad, or maybe the horn wiring is damaged and is shorting out somewhere. You need to do some testing
Received 1,442 Likes
Rep Power: 338 Re: honda civic 2017 horn goes off when turning the wheel
if within warranty, i would take to the dealer
Remove airbag......figure out how the horn contacts work. Might just need a little bending for clearance....
Could be a wire bundle not in the right clip causing the airbag to be preloaded toward a horn contact (used to see this sometimes after an airbag recall was done)
Take it back to whomever you bought it from (rebuilder?) and lodge your complaints, see if they will fix it.
Rep Power: 338 Thread
KarmaCivic
Electronics
11-04-2017 01:04 AM
krazykoncepts
07-18-2017 07:26 PM
boxinggsxr
01-11-2013 12:40 AM
zXeX
10-01-2012 04:27 PM
wfd2
01-05-2012 12:25 PM
