FS : 1200W amplifier
Power Acoustik
OV2-1200
• 1200W - 2 Channel Amplifier
• 250 x 2 watts RMS @ 4 ohm
• 300 x 2 watts RMS @ 2 ohms
• 600 x 1 watts RMS bridged mono
• Dimensions: 20 x 11.25 x 2.25
• Super Cool Blue LED
• Chrome Top Plate Panel
• Full Mosfet Power Supply
• PWM Circuitry
• Full Selectable Crossover Hi/Full/Low
• Three Way Protection Circuit
• Tri-Mode Capable
• Variable Low Pass 40Hz-120Hz
• Variable Hi Pass 150Hz-1.5Khz
• 18dB Bass Boost @ 40Hz.
• Frequency Response: 10Hz to 30Khz
• S/N Ratio:97 db
• THD: 0.02%
• 2 ohm Stable Stereo
• System Distress Indicator
• High/Low Level inputs With Floating Ground
• 4 Gauge Power/Ground Connection
• Gold plated RCA Connectors
• Line output
.. planned on building a bigger system, never got around to it.. used for about a month below half gain then put back in the box which has sat in my closet for a month or two, paid $140 new.. pictures should be attached
a_flanigan@hotmail.com or 248-672-1516
Fenton, Michigan.. local pick-up preferred for $100
but $120 SHIPPED
OV2-1200
• PWM Circuitry
• Tri-Mode Capable
• S/N Ratio:97 db
• THD: 0.02%
• Line output
but $120 SHIPPED
JAG609
Feb 6, 2003 11:02 PM
