FIRST OFF
BP1200.1 • Die-cast chassis uses the entire footprint for amplifier cooling
• "Direct-Connect" allows choice of 4 - 8-gauge power and ground cable
• High-frequency switching power supply is more efficient, drawing far less current from the vehicle's electrical system
• Four high-level and low-level inputs facilitate constant bass, regardless of head unit fader position
• Variable electronic crossover and bass-boost optimize subwoofer performance
Specifications MSRP US$: $549.95
Output 4 Ohms: 600W x 1
Output 2 Ohms: 1200W x 1
Signal-to-Noise (dBA): >100
Frequency Response (±3dB): 20Hz - 500Hz
Total Harmonic Distortion: 0.1%
Input Sensitivity: 250mV - 4V
USED FOR 6 months with warranty still active through manufacturer
$700 OBO
P80.4 • Variable 12dB electronic crossover allows the P-80.4 to be configured for a variety of applications
• The four channels of the P-80.4 can also be configured into three channels or even two channels - this allows for increased expansion capabilities and system flexibility
• Die-cast chassis uses entire amplifier footprint for cooling - and it looks awesome!
• High-output MOSFET power-supply topology doubles power into 2 ohms
Specifications MSRP US$: $279.95
Output 4 Ohms: 40W x 4
Output 2 Ohms: 80W x 4
Output 4 Ohms Bridged: 160W x 2
Signal-to-Noise (dBA): >110
Frequency Response (±3dB): 10Hz - 50kHz
Total Harmonic Distortion: 0.05%
USED FOR 6 months as well
ASKING warranty active as well....
$350 OBO
I also have 2 inifinity perfect 12's subwoofers...one is brand new one is 2 months old.....asking $300 for both if you want to see specs on the subs...
SUBS
please serious inquiries only....and of course no lowballers..
$700 OBO
$350 OBO
SUBS
I'll take one of Infinity Kappa Perfect. Brand new one preferably. I'll send you an e-mail about my offer.
Oh well... I couldn't find your e-mail address in your profile... How about $170 for brand new one? I assume they are Canadian dollars....
Just to make sure... this is Infinity Kappa Perfect 12.1 with single voice coil at 4ohm. Right?
I can pick it up.
Let me know. Thanks,
Just to make sure... this is Infinity Kappa Perfect 12.1 with single voice coil at 4ohm. Right? I can pick it up.
okay well the new one will be here in two weeks ...so i can hold it for you if you can wait.....the used one i can give to whoever gives it to me first...$130 and its yours..me email is marc_alday@hotmail.com
Quote:
Quote
[hr]Originally posted by: zoooh
I can pick it up.
Let me know. Thanks,[hr]
you are correct....Quote
stillmatik23, yo, left u a voice msg, just wondering, are there anything wront with the subs?have u break in the sub when u got it?and is it hooked up so that i can test when when i pick up?thanx
subs are already broken in nicely...nothing wrong with the sub...reason for selling...gonna get JL AUDIO 12W6 v2
warranty is only good until july...on the new sub that i selling you...reason being i has the subs for almost three years now...but only started using them in 2002...infinity updated the subs by making them more durable...so i had both replaced...at seperate times..the one i am selling used..only used it for about 2months...and the new one i am waiting for them to give me the new one....so its brand new..no problems with either sub...plus many ppl on this board have heard them...and they produce nice clean and exact bass
so the used one is from the new production also?i mean the one that they improved durability?
yes both of the subs are the second version that infinity came out with..so they are both GOOD!!
