Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
How much gains in low end by going back to stock intake from AEM CAI?
Old Feb 18, 2015
MrOldskool's Avatar
got rice?
MrOldskool is an unknown quantity at this point
Skimming over these posts. I have a stock '97 ex 1600 with exception of an exhaust header and a long aluminum piped aftermarket intake with a k &n behind the bumper. ( this is the way i obtained the car) It is a little sluggish obviously at low rpm and comes alive at 4k. Since I'm becoming an antique and I'm looking for mpg's more than screaming top end, my city mpg's are about 22 & highway around 34, Should I install a stock intake/filter to help with low end torque/mpg? And does the header effect the low end performance? Thanks.
Old Feb 18, 2015
GolNat's Avatar
Prelude Owner
Re: My take on intakes SRI CAI vs Stock
Yes converting back to stock would be best for MPG purposes. The headers will cause increase power in the top end so swapping them out should gain your low end back. Making sure the car is up in maintainance will too.
Driving habits play a big part in MPG. I don't know how much of an increase you will see with swapping back to stock.
Old Feb 19, 2015
MrOldskool's Avatar
got rice?
Thanks A bunch Gol, maintenance is up to snuff, valves set, timing set, new plugs, but having 244000 miles on the engine it may be a tad low on compression?.. I should be glad im driving a car that gets better than 20mpg now
ph0ng
52
Mar 4, 2003 09:15 PM
se7en
Nov 12, 2001 10:13 AM
AB
17
Nov 8, 2001 09:54 PM
godka0s
Nov 8, 2001 07:16 PM
skywalker
Nov 8, 2001 05:04 PM
