Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
96 ex 5 speed trans question
Old Jan 15, 2014
Drtydru's Avatar
Drtydru is an unknown quantity at this point
Hello,
I'm a new member/new civic owner. I just bought a 96 d16y8 1.6L vtec. It has a 5 speed and has been lowered, a lot from what I can tell. To get to my point, driving through all the gears is great. Very smooth with no grinding or slipping. I notice that when it's in gear, I can move the shifter quit a bit from side to side. Id say maybe 2 inches. I also noticed this morning that, with the car off, I can put it into any gear without engaging the clutch. My thoughts are that I need a new transmission. Can anyone shed some light on my issues?
Thanks.
Old Jan 15, 2014
Re: 96 ex 5 speed trans question
sounds normal...
Old Jan 15, 2014
Might need new bushings in the shifter linkage.
Old Jan 15, 2014
although moving the shifter side-to-side is that it's supposed to move to the sides, unless it's too soft.
Old Jan 15, 2014
da_bohl_swizzy's Avatar
da_bohl_swizzy is an unknown quantity at this point
to me that sounds normal all I ever owned were manual vehicles I could always shift in and out of gears with the car off and like ezone said needs new bushings cause the dude who had it was prob racing it rippin at the gears know this from experience replaced bushings a lot very simple fix tho but everything else is normal to me
Old Jan 16, 2014
Drtydru's Avatar
Thanks. So I need a transmission bushing replacement kit? Or what should I look into purchasing.
Old Jan 16, 2014
Read this again
You need to get under the car and see for yourself exactly which parts have excessive play and then refer to a catalog to see what parts you may need.
http://www.hondaautomotiveparts.com/...y5=SHIFT+LEVER
(I picked a random car for the pic. You need to start at the beginning of the site and choose your actual car.)
edspyhill09
Jun 12, 2016 02:45 PM
SinusoidalGraph
Transmission swap
Jun 26, 2015 04:43 AM
oneheadlight
Apr 29, 2015 11:30 PM
jackoncruzpr
Apr 16, 2015 12:29 PM
viper775
Dec 9, 2001 10:52 PM
