Adjusted throttle cable, removed resonator
Old Jul 23, 2002
BeefMan's Avatar
BeefMan is an unknown quantity at this point
Had some time to try the DIY on the throttle cable. Very easy to do and feels much better, no more play on the gas pedal. While I was under the hood I thought I would try removing the resonator box to see how that sounds. Ive heard it sounds a lot like having an intake. Only took about 10mins to take it off with the right tools. The sound you get from the engine is much deeper from around 2500-5000rpms. You also get a a bit of a swoosh sound if you rev it up real quick, not very loud though. As far as performance , it feels about the same. Im sure if you throw it on the dyno it might show a bit of a loss because its sucking in warmer air but I can't really feel it either way.
Old Jul 23, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
removing the resonator imo is not a good idea, sure u get sound (which doesnt win races) but you are sucking in air closer to the engine, instead of near the side
Old Jul 23, 2002
CivicStyle's Avatar
CivicStyle is an unknown quantity at this point
i Would have to agree with like Weeeee on this removeing the resonator box that is a bit of a cut back on Proformance. But in the same hand i myself like the sound i am sure u can find a nother way to make the sound still with out pulling the resonator box out.
Old Jul 23, 2002
BeefMan's Avatar
Like I said if you put the car on the dyno it would probly prove a couple ponies lost because of the warmer air but I can't feel it. The resonator easily bolts back on so its no big deal really, just an experiment.
Old Jul 23, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
why not just go buy a cold air intake? rofl. i got exhast and the resenator cut off on the piping so its pretty much a straight pip from the cadaylac converter with a injen race division cai and its done some really good performance ways for my car, better off the line and top end!!
Old Jul 23, 2002
slammed2k2's Avatar
slammed2k2 is an unknown quantity at this point
I removed mine too, but then it started raining and i live in a dusty new home area, so its not worth me sucking in water when it rains, or dust on a daily basis, so i put it back and im gonna wait for my AEM COLD AIR, that actually may give me some power and sounds much much nicer!
DAVE
Old Jul 23, 2002
BeefMan's Avatar
I was thinking I might try to make my own intake or if not go with the Injen race division cold air intake. I think the Injen would work very well with my Tsunami bumper. You should be able to see the filter through the bumper grill. That should be about the coldest air you can get. BTW Slammedcivic why would you suck in water or dust if you still have the filter in place?
Old Jul 23, 2002
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
I found the Check Point intake was the best for the buck. Got it off of Ebay for $85.00
It is chrome, but I think I would switch to the iceman since the metal gets very hot to the touch.
Old Jul 23, 2002
BeefMan's Avatar
Woohoo, I just scored an AEM cold air intake with bypass valve for a cool $100 off ebay.
Old Jul 24, 2002
Sim012's Avatar
Sim012 is an unknown quantity at this point
dayem!!! good deal
Old Jul 24, 2002
CapYoda's Avatar
Escaped Convict
both of thoes modification will result in worse mpg... heh.
as for the ebay auction.. I'm not sure if that includes the bypass valve.. he didn't really mention anything about it in the auction..s ure he has a pic of the "CAI" with the bypass valve... but he could just be trying to make it seem like thats a part of the deal.
Old Jul 24, 2002
BeefMan's Avatar
Why would removing the slack from the throttle cable result in worse gas mileage? Only difference now is that I dont have a bunch of play in my gas pedal, im not feeding the engine more gas or anything.
Old Jul 25, 2002
Silla's Avatar
Silla is an unknown quantity at this point
where's the resonator and how do i remove it? My car already sounds deep but if i could go deeper, like Jonny I would,(hehe) any help?
cukaracha
Jul 7, 2015 05:50 PM
Shakzhussain
May 17, 2015 12:03 PM
CiviCKiD
Jan 6, 2002 11:39 AM
CiviCKiD
Jan 1, 2002 08:02 PM
CrEePin01CiViC
Jan 1, 2002 11:29 AM
