ebay header question
Old Oct 14, 2016
drftsupramk2's Avatar
drftsupramk2 is an unknown quantity at this point
http://m.ebay.com/itm/Stainless-Steel-Exhaust-Manifold-Header-Fit-01-05-Honda-Civic-DX-LX-1-7L-SOHC-/232064844621?nav=SEARCH
Has anyone tried this header? I know it's going to be poor quality but i just need something temporary that fits. I have a d17a2 in a 2002 civic
Old Oct 14, 2016
GolNat's Avatar
Prelude Owner
Re: ebay header question
Most all cheap eBay headers are the same. There are some people on here that have them and them seem to holding up good. If you live in a rust free area they will last longer.
Old Nov 15, 2016
OneJzSupra's Avatar
OneJzSupra is an unknown quantity at this point
The only issue I've seen is that check engine lights from deleting the cat.
Old Nov 15, 2016
mac25's Avatar
Dr Krieger of Modification
I've had one for over a year.
EBAY is not a brand, it is a store.
-If you're buying a product that ships from the States usually it will be high quality.
-A header is not safety equipment like brake pads/rotors, seat belts or a steering wheel; even if it cracked there would be no damage to the vehicle or to yourself.
-A header is four pipes it's really not that hard to make right.
Go for it =D.
Old Nov 16, 2016
SammySC's Avatar
SammySC has a spectacular aura aboutSammySC has a spectacular aura about
I am installing a 4-1 DC Sports ceramic header today. No need to remove the cat on my 02 Ex Coupe for this install. I know I will not see the full increase in HP by not removing the cat but I dont want to have a check engine light on and I want to pass emissions. I am considering a high flow cat in the future I found Magnaflow makes them for my car.
Name:	DC sports 4-1 ceramic header.png
Old Nov 17, 2016
OneJzSupra's Avatar
Originally Posted by SammySC
I am installing a 4-1 DC Sports header today. No need to remove the cat on my 02 Ex Coupe for this install. I know I will not see the full increase in HP by not removing the cat but I dont want to have a check engine light on and I want to pass emissions. I am considering a high flow cat in the future I found Magnaflow makes them for my car.
The cat is part of the downpipe on the factory manifold. You would have to make a custom setup and extend the wiring harness to move that the secondary O2 sensor after the cat. You would also have weld in a bung after the cat as well.
Oops... Just noticed that's just how it is on my LX.... which is apparently different from your setup haha.
Old Nov 17, 2016
SammySC's Avatar
haha OneJzSupra yeah on the EX the cat is further down, on the down pipe. Very easy installation on the 02 EX. Didn't even had to unscrew the oxygen sensors or anything!
Old Nov 17, 2016
SammySC's Avatar
Here are a couple of pictures after the installation. Super easy to do. I bought all new gaskets and spring screws to make it a super clean install! Enjoy!
Name:	DC header installed 1.jpg
ID:	89248   Click image for larger version
Name:	DC header installed 2.jpg
Old Nov 17, 2016
OneJzSupra's Avatar
Looks pretty good, is the rest of your exhaust factory? If so have you noticed any improvements in sound / power?
Old Nov 18, 2016
mac25's Avatar
nice =D 'm also running the DC strut bar like you.
Old Nov 18, 2016
SammySC's Avatar
I have a 4" rolled tip cat back exhaust system by DNA racing but still have the original cat and down pipe unfortunately. I noticed a slight increase in mid range power with the header as well as smoother acceleration and idle. Won't get the full benefit until I install a high flow cat. I'm going to start looking for a tuner friendly muffler shop in the area. I am looking at a Magnaflow high flow cat but the down pipe has to be customized. I will probably wait until the spring.
Old Nov 18, 2016
SammySC's Avatar
Cool do you have some pics of your ride?
Old Nov 18, 2016
SammySC's Avatar
This is the cat back system I installed. I modified it to my taste with some high temperature black paint. The only chrome piece I left alone was the rolled tip and I'm still considering painting it just to be different.
Name:	Catback exhaust.jpg
Old Nov 18, 2016
SammySC's Avatar
This is what it looks like painted showing just the chrome tip...
ID:	89258   Click image for larger version
ID:	89259   Click image for larger version
Name:	new rear 2.JPG
Old Nov 20, 2016
mac25's Avatar
Your car's looking good =D.
Ya go to https://www.civicforums.com/forums/4...5-build-3.html
Old Nov 20, 2016
SammySC's Avatar
Thank you mac25!!
Old Nov 20, 2016
SammySC's Avatar
I checked out your ride mac25, very nice indeed!!
Old Nov 21, 2016
mac25's Avatar
Thanks, she's a work in progress
20% rice, 70% race, 10% broken, lol.
Old Nov 22, 2016
SammySC's Avatar
LOL I like that ratio it makes it fun
Old Dec 1, 2016
What intake is that?
Old Dec 1, 2016
I have a d17a2 2002 civic lx so im a little confused which header to or where my 2nd 02 sensor plugs into
Old Dec 1, 2016
SammySC's Avatar
I have the K&N short ram air intake.
Old Dec 1, 2016
SammySC's Avatar
Check out this thread it is very helpful:
https://www.civicforums.com/forums/1...-question.html
Old Dec 2, 2016
hopefully this illustration helps you with the difference between the ex (d17a2) and dx/lx (d17a2) exhaust setups
Old Dec 7, 2016
so from your diagrams here is what i have.
D17a1 exhaust, 2002 civic lx with a d17a2 engine it. I believe it has a d17a2 engine harness because i only have 1 02 plug next to my slave cylinder. So basically i am screwed on the second sensor? Any options. I read a little on swaps like d17a and they were talking about repining a connector
Old Dec 7, 2016
Thanks for your help everyone! I was an mk2 supra guy for years. First honda
dsm482
non-VTEC to VTEC Head swap
Mar 29, 2016 04:39 PM
MamaBear2015
Electronics
Mar 15, 2016 06:19 PM
MamaBear2015
Exterior
Mar 3, 2016 09:56 PM
Blazeomar
Jan 20, 2002 08:55 PM
Sledge
Dec 7, 2001 12:09 PM
