2005 honda civic exhaust dx, lx vs ex
Old Apr 5, 2016
dsm482's Avatar
dsm482 has a spectacular aura aboutdsm482 has a spectacular aura about
Hi,
i have 1.7 d17a1..
I read a lot someone verify for me..
I know the stock exhaust are diffrent betweend vtec and non vtec, dx,lx vs EX vtec one..
I would like some aftermarket headers.. will they fit both, or are there diifrent ones for dx or d17a1?
how did you guys modify the o2 sensor.. was it fine just extending the wire it for the CEL leght?
I was thinking buying a header, and do 2 inch or 2/14 inch exhause back with some deep tone muffler , nothing to loud.. and add a 50 shot nitrus... i just want to make it breath better.. car is old, but i love it..
millage is high, but had 200 compression before my valves got bent.. so i put some new valves,, .. cheap best for buck performance am looking at.
turbo or swaps are just to much for this car.. i rather buy somehting fast to modify.
Old Apr 5, 2016
Poopies's Avatar
Super Moderator
Re: 2005 honda civic exhaust dx, lx vs ex
The D17A1 header has the catalytic converter attached to it, while the A2 (EX) header is its own thing with the cat located past the downpipe. Unless you convert to an EX-type setup, there aren't many exhaust options available to you, especially for headers.
Old Apr 5, 2016
dsm482's Avatar
I realize that i read the thread above in sticky..
my questions is will I be able to modify extend the O2 sensors.. extend = more resistance= CEL light. Here in NYS where am at , they hook the car up to computer, and wont pass inspection if you have Check engine light.
No cat no back pressure, I was thinking running eventually 2inch exhaus back.. nothing bigger j so i dont loose all backpressure... I can put a dummy cat for the inspector, that means clean the internals out.
main problem is will it set CEL light.. if it does i have an issue.
Old Apr 5, 2016
Colin42's Avatar
you can buy o2 sensor wire extensions, and they shouldnt cause any issues
Old Apr 5, 2016
dsm482's Avatar
How big is the cat on EX civic outlet an inlet..? if I grab there cat cut it out, and cleaned the internal, get a header from the head, then run 2 inch to that cat, and 2 inch back to a muffler.. get wire extendors header i believe has a spot for o2 at it,.. where would it be the second 02..
on dx its right after cat.. on the header part..
my worry is backpressure, and not reading right, at certain condition settin CEL or setting CEL constant..
any experience with it ?
Old Apr 5, 2016
dsm482's Avatar
bump.. anyone had issues with their set ups on dx or lx..
I need to know if CEL light can be avoided. NYS hooks the car up on inspection once a year.. no smog test, but needs to have no CEL's.
I found this megan header for LX an DX.. it has 2 bunks for O2 right were the cat is on the OEM.. But having no cat on this MEagan makes me think, no back pressuer as much, would that trip the O2 sensor anyway?
http://www.meganracing.com/product.asp?prodid=323 this is the one I am talking about that i Found...
There has to be people with aftermarket exhaust..
I just want to make sure I can avoid CEL... otherwise it will be a bitch hooking your stock exhaust back up once a year to just pass inspection.
Old May 4, 2016
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
No CAT = CEL. The megan racing header will cause the CEL to come on because there is no cat. If you get the EX exhaust and gut out the cat for a "dummy" cat, it will also throw the CEL.
Old Nov 8, 2016
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
I have an 05 lx.
I recently installed a header by tuner bits (amazon)
I couldn't mount the secondary 02 sensor...so i put it in a plug defowler..which i drilled out and put it next to the battery. (out of laziness)
i have tripped the CEL a few times, but i now run a bluetooth elm327 obd2 device to my tablet...which is mounted on the dash. I use the app Torque pro for more telemetry and this will also clear any CEL that may occur...
Old Apr 11, 2021
YahBoyAllyG's Avatar
YahBoyAllyG is an unknown quantity at this point
Yo homie was wondering if you could help out. Soo I have a 2005 Honda Civic dx coupe (D17a1) with a stock exhaust, Could you maybe recommend any exhaust that are compatible with the oem catalytic converter and also if you could maybe give me tips and specs on the actual size of my oem piping and kinda teach me what I need... I hope you reach out, the civic would really appreciate that
one last thing do I need to basically swap the exhaust from a EX to My civic coupe for it to work ?
Old Apr 12, 2021
https://www.civicforums.com/forums/2...p-version.html
TRIZ
Bolt-on Engine Performance
Jan 19, 2022 09:42 PM
TRIZ
SOHC D17Ax non-VTEC - VTEC Engine Swaps
332
Apr 7, 2016 12:32 AM
TRIZ
332
coopertiresrac
Dec 9, 2010 01:15 AM
mohawkboom
Mar 5, 2002 10:52 PM
