car sputters after being left off.
Old May 31, 2013
piotr's Avatar
piotr is an unknown quantity at this point
Hey everyone! forgive me if this has been covered else where however i'm new and I couldn't find it.
I got my 2002 civic si about a month ago and the problem it has is as follows! The car starts and runs amazing, no problems at all; however! if the car is turned off for anywhere from a few minutes up to about 45 minutes then when it starts again it has no power and stutters and stumbles until about half a minute of me reving it to about 6g's passes.
As an example, if I leave my driveway and go to the store, spend 10 minutes to an hour in the store, get back in my car and start it the damn thing barely runs until it "catches" in about 30 seconds. If the car is parked for a few hours then it starts and runs like a dream!
any ideas?
Old Jun 23, 2013
go-part's Avatar
Former Sponsor
go-part is an unknown quantity at this point
Re: car sputters after being left off.
Do you have the service records?
You need to figure out if this is a fuel, spark or timing issue.
http://www.ehow.com/how_5045801_fix-...ar-engine.html
Old Jun 24, 2013
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Mine didn't sputter, but I lost most of my power for the first couple minutes after starting cold when my upstream 02 censor was bad. When I would give it 70% throttle or so it would jump to life since it was running off the fuel map and not the 02 readings. Under that amount it would feel like it was bogged down and the revs would be super low.
Old Jun 24, 2013
Old thread is old, but I'd think about a fuel pressure check.
Specifically looking for if it can retain residual pressure after the engine is shut off. If it bleeds off pressure before the engine cools down, the fuel boils in the rail and you end up with -- essentially -- vapor lock.
Poopies
Apr 20, 2017 11:36 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
GH04si
Apr 15, 2015 08:13 PM
SSMatey
Apr 13, 2015 06:09 PM
WSRcivic
Detailing
Nov 1, 2001 11:10 AM
