Non v-tech to v-tech ?????
Old Oct 5, 2012
Deadlyshaddow's Avatar
Deadlyshaddow is an unknown quantity at this point
Alright well blew my motor up like when i say blown up i do it the right way it aint done till it wont start back up or things are fling out of it. Anyways theres a 2" hole in the side of the block right behind the a/c compressor braket so blocks no good.
The question is can i take a non-v-tech bloch and remove the head and put my v-tech head on the top an still have v-tech or is it one of the i need to run an oil line. The difference is 400$ and im sure i can buy some very nice looking oil line with 400$ to spare. So if theres some one who can point me in the right area give me pictures anything at the moment i need my 40mpg back. Haha.
This is the hole and snapped rod haha
Old Oct 5, 2012
Re: Non v-tech to v-tech ?????
You didn't post what year your car is.
Looked at 01 and 05 regular 4 door Civics in the (USA) parts catalog. All versions (DX/LX/EX) use the same block part number in each of those 2 years checked.
So I'd say you should be ok.
Look the cars/engines up yourself to be sure:
http://www.hondaautomotiveparts.com/
http://estore.honda.com/
HTH
Old Oct 5, 2012
Sorry man the car is an 02 honda civic ex the motor is a D17A1 thats all i know haha. Never really did anything with a honda to be honest i do V-8s fords chevys stuff like that nothing foriegn so this is kinda new to me haha.
Old Oct 5, 2012
02 block is still the same part number (11000-PLM-810) as above.....(1.7 liter)
Old Oct 5, 2012
Sweet so the only difference if the head and as long as my head is fine the block will put oil to the v-tech control valve and will hit v-tech like normal.
Old Oct 5, 2012
You probably need to thoroughly clean out the head.
Check this:
Originally Posted by ezone
See, when a lower end bearing lets go, it normally sends bearing material and crank material all throughout the entire lubrication system. That means metal will end up in the cam journals and the VTEC system (when equipped) and the rockertrain-rocker arms, shafts.... EVERYWHERE.
The metal debris can hide in the damndest of places.
If it isn't ALL cleaned out thoroughly, then it can be just a matter of time until it trashes something.
3M Scotchbrite Roloc gasket grinder discs can really trash a set of bearings in a hurry too. Those are a strict no-no when doing internal engine work.
Old Oct 5, 2012
Ya i know that but can the non vtech bottom end like pistons, rings, rods, crank, bearings. Most importantly can the oil pump handle the kick of vtech.
Old Oct 6, 2012
The short blocks are ALL the same in the parts catalog. Zero difference.
And there is no "H" in VTEC.
Old Oct 6, 2012
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
I thought the oil was supposed to be on the inside of the engine.
Old Oct 6, 2012
It's only a little hole. I bet there is some oil left inside.
Old Oct 6, 2012
if you have an EX and the engine is an A1, it have already been swapped once.
Old Oct 7, 2012
Oh ya it has been replaced before, i did it before to haha.
silver97EK
Engine Swaps
Sep 15, 2018 06:21 AM
Kenji_Shinomori
Jun 22, 2015 03:33 AM
pichon
32
Sep 18, 2003 01:35 PM
supermex
23
Jan 1, 2003 01:14 PM
