EVO 2 resonator buzz
Old Jun 12, 2007
Lord ET's Avatar
Lord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of light
Has anyone else with the evo2 midpipe had an annoying metallic rattling or buzzing sound when they step on the gas? (It sounds like it's coming from inside the resonator.)If so did you fix it and how? i suppose i could also ask does anyone know what's making this noise and how i might fix it? Thanks
Old Jun 12, 2007
Lord ET's Avatar
Re: EVO 2 resonator buzz
anyone?
Old Jun 12, 2007
Rennen's Avatar
New Mod on the Block
i dont get any rattling from my evo2...
Old Jun 12, 2007
xxxcivic2001's Avatar
xxxcivic2001 is an unknown quantity at this point
i get the same noise...someone fix it!
Old Jun 12, 2007
Lord ET's Avatar
i've read on honda-tech that it might be a loose baffle (or a bad baffle) inside the resonator.. can anyone confirm this theory, and is it fixable? I've only had the exhaust on for 3 days so idk if i could return it....i bought it from truehonda like 3 or 4 months ago and was finally able to put it on this weekend.
Old Jun 12, 2007
TOEnail's Avatar
TOEnail is a jewel in the roughTOEnail is a jewel in the roughTOEnail is a jewel in the roughTOEnail is a jewel in the rough
i use to have that sound but my evo2 didnt have any flange/gaskets. bought some at pep boys and once i put them on the sound was gone.
Old Jun 12, 2007
Lord ET's Avatar
hmm... i do have on the gasket that came with the evo2 so maybe i'll try another gasket i have that's not what appears to be metal.
Old Jun 13, 2007
Rennen's Avatar
i got a new gasket from pepboys as soon as i got it. i bought it used off ruffryde009. just bring in whatever gasket you have now and have them get an exhaust gasket that matches it. im pretty sure i got a Mitsubishi talon one or something like that.
Old Jun 13, 2007
D5cIvIc's Avatar
its probably leaking air at the resonator connector. Get a new gasket, won't hurt if you try that. good luck
Old Jun 13, 2007
Lord ET's Avatar
thanks i'mma do it right now
Old Jun 27, 2007
Lord ET's Avatar
well new gasket didn't work... I had to call greddy and get an RMA so i can send the pipe back for them to examine...
Old Jun 27, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
is it your heat shield? like well does the evo 2 have a heat shield?? n e wayz, i know my vic was rattling a while back and it ticked me off, but all it was was one tie for my heat shield under meh car just needed to be tightened.
Old Jun 27, 2007
GMusicLife's Avatar
GMusicLife is an unknown quantity at this point
idk if this has anything to do with my evo2 exhaust but I am getting a rattle during downshifts at 3500rpm, anyone have some insight on that?
Old Jun 27, 2007
01EXGUY's Avatar
01EXGUY will become famous soon enough
ha!!!! im not the only one!!! mine has the same metal to metal noise, and when i checked everything out, it was fine.....no loose connections or flanges and plenty of clearance around all the piping. it doesnt do it all the time though just once every few days but its soooooooo friggin annoying........we need to figure this s*@# out!
Old Jun 27, 2007
Lord ET's Avatar
I also thought it was my heat shield so to make sure of it i coated the top of all of the stock heatshields with silicone and they don't make a sound now....but alas it was not that. I will be sending my midpipe and i guess muffler into greddy within the next few days so hopefully i can get an answer and help to shed some light on the matter.
Old Jul 2, 2007
GMusicLife's Avatar
well if you think that's bad, listen to this lol. when it rains it sounds, and feels like my exhaust is rattling against the bottom of my freakin car! I can feel it in the passenger side floor board! any idea what that is all about? again, it only seems to be when its pretty wet out... hmmmm
Old Jul 2, 2007
Lord ET's Avatar
I had that problem except instead of only doing it when it rained...it did it anytime i let off the accellerator That was on a 3.5hr road trip.... after i got home i readjusted the pipe to sit as far from the underside as i could and it stopped doing that...THANK GOD!! But i've heard geting some longer hangers will fix the raining undercarriage thumps.
Old Jul 2, 2007
GMusicLife's Avatar
any idea why it does it?
Old Jul 2, 2007
Lord ET's Avatar
well mine was just a little too close to the car and when weight would shift and resonant frequencies came into effect the midpipe would bend and shake...hitting the car. mine hit just after the bend so i put some silicone where ti hits and that helps.
Old Jul 2, 2007
01EXGUY's Avatar
man, that is EXACTLY what mine is doing!! when it rains for some reason it sounds horrible. wonder what the hell this could be?!
Old Jul 2, 2007
SEN_ONE's Avatar
SEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of light
I get a nasty sound from mine when it's raining. It doesn't do it every time it rains, but it is annoying.
Old Jul 3, 2007
D5cIvIc's Avatar
guys don't owrry its a common problem, its due to the fact that when it rains the water hits ur exhaust causing the metal to contract and expand, thus causing the vibration.
nothing to worry about. just watch out for puddles. mine does it too. its normal for the evo to do this
Old Jul 3, 2007
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
yea...i went back to the stock exhaust because of those issues... oh and for my tickets :P
Old Aug 28, 2007
Canadian Si's Avatar
Canadian Si will become famous soon enoughCanadian Si will become famous soon enough
I just made a thread about this ! I should os SEARCED 1st But now after reading this I am somewhat glad I am not the only one with this issue & there isn't something wrong with the car. I am still gonna take it to a shop to see if they can adjust it alittle
Old Aug 28, 2007
DsevenEm2's Avatar
This is Myspace
told u... ur welcome.
yyyktk1
Sep 12, 2015 04:02 PM
muniorbust
33
Aug 31, 2015 08:59 PM
cukaracha
Aug 27, 2015 02:02 AM
liamfry91
Aug 9, 2015 07:54 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
