rsx exhaust tip question
spell check pwns you
ok im getting a 2004 rsx-s exhaust axle back and wanted to know if i could put the 05-06 exhaust tip onto it?
ay answers that are helpful will be repped.
A long winded 7th genr
You should be able to get someone to cut off the old, and weld on the new tip. The pipe diameter should be the same for both years. Even then midas or any muffler shop can stretch the opening a bit to make it work if not. You could probably go to a junk yard cut off the tip with out anyone knowing!
Red_Chaos1
Jun 21, 2015 01:12 AM
PierrePierre
Jun 17, 2015 06:22 PM
