Looking at intakes...searched but didn't get what I wanted.
Old Jul 16, 2006
  #31
MarkieMark's Avatar
MarkieMark will become famous soon enough
ahh just keep it stock.
or grab a k&n drop in filter like i did.
Old Jul 18, 2006
  #32
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
well i just installed the weapon-r secret intake and it was a bit of a pain in the *** to get the bracket bent, installing the hose, and had to some how install the ait without it fallin out. overall it was a pretty easy install just wish they welded a bracket onto the intake like the k&n typhoon instead of making us bend it and have it semi holding up the intake. then the hose they provided to hook up to the outlet on the intake to the breather outlet on the engine, was such a pain to get it on b.c it was like the exact size of the outlets so u had to mess around alot to get it on. then they made the ait sensor hole a bit larger than the sensor so it would just dangle in there and with a lil bump it would fall out so i just took some electrical tape and wrap it around the sensor and shuved it in...it works..but ghetto.
will be goin out in a couple hrs and see how it is and will take some snap shots of it.
Old Jul 18, 2006
  #33
oh yea lol i forgot about that. some electrical tape works fine with the sensor. did you have to extend the wires?
Old Jul 18, 2006
  #34
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
Hey gearbox I didnt know anything about putting oil on. So where does it go? I have had mine fopr 2 years now and never put oil on mainly cuz I didnt realize I had to. where and how often does it need to go on?
Old Jul 18, 2006
  #35
lxcivic2k1's Avatar
Thats what I decided seeing that it doesn't do anything...just thro the K&N filter in and be down with it...much cheaper too.
Old Jul 18, 2006
  #36
hmm yea it needs oil. i mean foam by itself does not work that great... it needs oil on both sides covering all the material so its sticky. and it must be foam oil. i would pick up a foam cleaning kit and just clean and oil it.
Old Jul 18, 2006
  #37
crazyasian's Avatar
yea they were already extended when i was doing another project so i have about i would say 10 inch of slack. only thing thats really pissing me off is the bracket they provide....it doesnt hold the intake up or wat i did. im wondering if i can take a bracket and just weld it on to the intake like the k&n typhoon. got any suggestions gearbox? currently the intake is just slouching with basically no support to hold it up b.c i cannot figure out a way to hold the intake up with the dumb bracket.
i pretty much oil mine up in a zig zag motion but applied alot all over the place but not like its drenched in the oil but enough. i found out that they provide the oil and cleaning stuff with the intake so i just waisted 20 bucks o well more to get it cleaned again in the future.
Old Jul 18, 2006
  #38
idk, i was trying to search for a stronger bracket that isnt made of soft metal that sags. and it bends down now im afraid the rubber boot holding the intake on the tb will crack. altho its been a year and so far good. might get a new one from autozone anyway. but yea thats at the end of my project list but i'll let you know.
Old Jul 19, 2006
  #39
crazyasian's Avatar
yea i wonder if i can weld a bracket like the K&N typhoon intake but problem is that its a high grade aluminum(sp?) something like 6061 aluminum. nd not many places around my area dont do welding on aluminum so idk. need to find a way to mount the intake well. i did notice 2 tiny holes on the intake piping but not sure wat those are for....if they are a place i can screw down the plate on that i might do that. idk let me know wat you can think of.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
alaga
25
Aug 13, 2015 04:42 PM
adamdrives
15
Aug 8, 2015 08:53 PM
viperGTS
Jul 27, 2015 08:40 PM
1khilari
Jul 9, 2015 08:12 PM
