Mid pipe problem!
Old Aug 16, 2005
SilvercivicLX02's Avatar
SilvercivicLX02 is an unknown quantity at this point
Mid pipe problem!
I got mid pipes for a cat back exhaust, but the pipe ends abruptly with a flange on the end to bolt on to something, but theres nothing to bolt on to. How can I fix this?
Old Sep 3, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
so you have 1 flage after the cat, then mid pipe, then at the end of mid pipe you have another flage that should connect to a pice of pipe to you're muffler.
Old Sep 5, 2005
anibal's Avatar
anibal is an unknown quantity at this point
assuming on your user name, you have an LX. The midpipe of the EX is different than the other models. The EX has the cat under the car, close to e-brake, while the other models have the cat as part of the exhaust manifold and the midpipe runs all the way down to the manifold. Meaning you probably got an EX midpipe and need an extension to make it fit into your car. I'm sure a good muffler shop can help you with it.
MN-02-CivicEx
28
May 2, 2015 09:11 PM
DriftR
Aug 23, 2005 03:57 PM
1028CiViC
Dec 16, 2001 07:37 PM
netcbc
Nov 8, 2001 05:57 PM
netcbc
Bolt-on Engine Performance
Nov 7, 2001 01:29 PM
