Engine / Torque Dampener - anyone using this
Old Mar 31, 2004
PunkingCivic's Avatar
I need TP for my bunghole
Engine / Torque Dampener - anyone using this in a 7thgen.
The pic below is one installed in a ep3 aka: SI HB.
Old Mar 31, 2004
2k2civic's Avatar
Doesn't look like it'll do much unless all three mounts are replaced with something similiar to the damper. Besides, shouldn't need it unless you pushing some large numbers.
Old Mar 31, 2004
I believe it lowers the amount of engine rocking back and forth.
which i would assume gives you better power response
Old Mar 31, 2004
blouisgod's Avatar
Life Begins > 6800rpms
Those are sweet. Ive been looking around and havent seen any for the infamous d17.
Old Mar 31, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Old Mar 31, 2004
Intruder's Avatar
Intruder is an unknown quantity at this point
They are a nice alternative to polyurethane mounts. But since they don't make them for our car, and I didn't care to fabricate brackets, I just polurethaned my rear mount and its all good. Only difference is a PU mount will cause alot more vibration that the dampener will.
Old Mar 31, 2004
dezod's Avatar
7thgen Power Maker
Ingalls I believe makes a piece like that for a couple of cars.
http://ingallseng.com/graphics/Prodc...ures/93011.gif
Old Mar 31, 2004
civicvtec1ps's Avatar
Search and Learn
Ingalls released Engine Dampener for ep3 and dc5.
Won't work with d17 motor though =/
Old Mar 31, 2004
gipperkid's Avatar
gipperkid is an unknown quantity at this point
This should be the next DIY for our cars. Anyone have any spare time?
Old Mar 31, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
oh i want one. i might just make it fit.
Old Mar 31, 2004
They make universal kits and sell them on ebay for 40 Bills.
I just don't know where to put it and how it sould be put on in relation to the motor.
In the front or on the back.
http://search.ebaymotors.com/search/...0&BasicSearch=
here are the sizes on ebay
172MM-186MM
or
305MM-319MM
Old Mar 31, 2004
here is the other
Old Mar 31, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
put in ne where u can. try using an area in the bay where the mounts are bolted to.
oh im bout to get one.
Old Mar 31, 2004
I'll look in the engine bay when I get off work and see wher the hell I can attached to engine and body. If you figure something out post it. I'd rather bolt then weld to the frame.
If you get please do a DIY
Old Mar 31, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
hmm im gonna look at my bay right now.. ill brb.
Old Mar 31, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
ok if we're gonna mount this thing topside in the bay meanin on the top on the engine in view as opposed to under the engine.. i can only see ONE place on the engine to bolt it to. which is the driver side motor mount braket. as for mountin to the frame.. well we can either use one of the 3 bolts for the mount on that side or we're gonna HAVE to weld a plate on.
Old Mar 31, 2004
gotcha! I'll still look later and come up with some ideas and take some measurements so I know what MM damper to get.
We might have it!!!!!
Old Mar 31, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
yea lets brain storm how to do this ****.. i want this.
Old Mar 31, 2004
RiceBuRNeR's Avatar
Turbo Member
I can fabricate the weld on tabs, as soon as someone tells me what size we need Ill order one and get crackin on the tabs!
Old Mar 31, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
isnt that what they come with?
Old Apr 1, 2004
thecheat's Avatar
thecheat is an unknown quantity at this point
I found a place that sells one made for our cars, D17 and all.
Go to jhpusa.com
I think they wanted like $100 for it but its adjustable and made really well. Adjusts so you cna make it soft and not get all the vibrations coming through when your jsut cruising around and then tighten things up when you need too. Although the $40 thing sounds cool too
Old Apr 1, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
Go to jhpusa.com
well link me cause all i see is K , and B SERIES no D.
Old Apr 1, 2004
thecheat's Avatar
I called and talked to the guy there a while ago, he said they had one for the D. I'll call again tomorrow and double check, but I was real clear that I meant D and not B. I think the damper was made by J's racing or something like that.
Old Apr 1, 2004
blouisgod's Avatar
^sweet.
Old Apr 1, 2004
blouisgod's Avatar
The ones on the ep3 adn the dcs have the brace going perpidicular to the engine and the mount, meaning that the brace is, if your looking at your engine from the front, mounted parallel to the fenders. I think this makes the most sense in absorbing shock as the engine rocks front to back. Most on ebay have them mounted diagonally or horizontally.
Old Apr 1, 2004
blouisgod's Avatar
http://ingallseng.com/parts/stiffy.htm
No 7thgen.
Old Apr 1, 2004
cwick187's Avatar
cwick187 is an unknown quantity at this point
I'll do some research to if I can find the time...I would like to make it work to get rid of that wheel hop
Old Apr 1, 2004
sorry fellas I didn't have a chance to measure. I want a bolt on solution. I happy to see us working together to advance the 7thgen a little further.
It like our car is the redheaded step child most people forgot about when making products.
Old Apr 1, 2004
does anybody have a good engine bay shoot of the driver side from above that section of the mount and driver strut mount area?
I can photochop this thing on the car to get an idea.
Old Apr 1, 2004
blouisgod's Avatar
^def.
I got this pic, its a lil older but may work.
