K&N FIPK or Typhoon?
Old Oct 17, 2003
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
Which do you think is a better intake?
Need opinions and experiences please
Old Oct 17, 2003
hothondacivic02's Avatar
hothondacivic02 is an unknown quantity at this point
Fipk is short ram and typhoon is bolth also Fipk has heat shield
Old Oct 17, 2003
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
FIPK II all the way - it sounds sick and gives awesome performance
Old Oct 17, 2003
SlickCivic2K3's Avatar
SlickCivic2K3 is an unknown quantity at this point
Looks = Typhoon
Performance = I don't know. Check www.carreview.com and check different reviews on those products. Personally, I would go for the typhoon because it looks better. I am not sure if the heat shield would really help that much. That's my two cents.
Old Oct 17, 2003
civic-king's Avatar
civic-king is an unknown quantity at this point
what is the typhoon?
is that the one with two filters?
Old Oct 17, 2003
http://www.knfilters.com/typhoon/
Old Oct 18, 2003
civic-king's Avatar
well....that's lame.
go for the FIPK II. it's more heat resistent, and your filter won't git plugged as easy. (or soaked, depending on where you live)
Old Oct 18, 2003
I've seen dyno charts for the FIPK II and you still lose a little low end. It will only help if you always accelerate past 4K rpms. Heat shield is useless because the whole engine bay gets hot and the air moves around under there. Just stick with the stock setup and get an OEM K&N dropin filter.
S1N7H3T1C
Aug 28, 2015 01:00 PM
rzc
Bolt-on Engine Performance
17
May 15, 2003 04:57 PM
Friedrice
Mar 27, 2003 08:37 PM
IronFist
20
Nov 13, 2002 10:47 PM
Boosted2k2
16
Sep 2, 2002 02:18 PM
