Best Intake for a 03 EX
Old Nov 2, 2003
  #61
YAGATAWANA's Avatar
YAGATAWANA is an unknown quantity at this point
I have a V2 on a stick EX. It is not really a CAI as the filter is high up right behind the battery not down low like the two peice CAI. Upside no perceived loss of low end definate increace 4K-7K ,being up high less chance of water ingestion. Downside, noisy, pricey, location of port for temp sensor too far away from stock that sensor wires needed to be lengthened, at least the way my harness was.
Old Nov 2, 2003
  #62
IronFist's Avatar
Originally posted by YAGATAWANA
I have a V2 on a stick EX. ... Downside, noisy, pricey, location of port for temp sensor too far away from stock that sensor wires needed to be lengthened, at least the way my harness was.
^ See, why do companies release stuff that doesn't fit. That's crap. FIPK II fit perfectely. Everything was the correct length, everything fit into place, etc.
Old Nov 2, 2003
  #63
orion_squall's Avatar
so FIPK II is really silent? only make sound after 4000rmp?
anyone else can confirm that?
Old Nov 2, 2003
  #64
01EXplain's Avatar
01EXplain is an unknown quantity at this point
I bought the Injen Race Division CAI. It looks great in blue with red trim, and gave solid top end, but after around four grand, it gets kind of vociferous. I didn't notice any loss of torque, and it only cost $183 for an anodized true cold air. But I haven't heard anything negative about the K&N systems and they are around the same price. And about the dangers of vapor lock from its location, I duct-taped all the openings around the filter and drilled holes where the foglights would go for it to breath, plus it gave it kind of a ram air effect. No regrets other than the raucous growl in high rpms.
Old Nov 2, 2003
  #65
Novaz3's Avatar
Novaz3 is an unknown quantity at this point
everyone knows that adding a CAI or SRI that you lose low end TQ but make up for it in the High End area. However no matter what intake you add to your EX civic the gains will be minimal if any, dont aspect a Rocket once the intake is added. I was thinking about investing money into making my Civic faster but i would save more money just buying a stock WRX and calling it a day
Old Nov 2, 2003
  #66
YAGATAWANA's Avatar
Put 10 large into a new civic coupe and you'll have a wrx beater with 5 in your pocket.
Old Nov 2, 2003
  #67
Majarvis's Avatar
Majarvis should not be trustedMajarvis should not be trustedMajarvis should not be trustedMajarvis should not be trusted
What would be better? A K&N FIPKII or the Typhoon SRI?
Old Nov 2, 2003
  #68
Novaz3's Avatar
niether if you want to tap the most potential out of your civic go with a AEM Cold Air Intake if you decide to go the Short Ram Intake Route go with Dragon or Injen Short Ram a K&N filter will do nothing for you besides waste your time and money
Old Nov 2, 2003
  #69
Majarvis's Avatar
I don't want CAI because of our winters and I don't want a crappy company either, that's why I asked about the K&N, I didn't ask about any other companies, just those two products...
Old Nov 2, 2003
  #70
Novaz3's Avatar
oh my fault i wasnt trying to be rude or anything just wanted to let you know that the research done on the drop in K&N filter has shown that the gains are 1HP increase to -2HP decrease basically meaning you will get little to no gains. The Typoon intake i havnt read in results from Dyno testing regarding its performance so i cant comment on it
Old Nov 2, 2003
  #71
Novaz3's Avatar
i hate winter also i have a set of Motegi FF5 17 inch wheels that im dying to put on my ride but im going to wait till winter is over because i dont want to mess them up. I have a DC sports Twin Canister exhaust and was considering a CAI AEM intake but again im going to wait till spring breaks so i can make my final decision
Old Nov 2, 2003
  #72
Majarvis's Avatar
No no no, the K&N FIPKII isn't a drop in filter, it's an SRI, with a heat shield included. The K&N Typhoon SRI is the same thing pretty much just minus the heat shield, but I'm just wondering what the difference between the two are...
Old Nov 2, 2003
  #73
Majarvis's Avatar
Isn't the DC Sports TCS cat-back as restrictive as the stock system?
Old Nov 2, 2003
  #74
Novaz3's Avatar
im sorry but you do lose low end TQ when you add a intake. thats the only bad part about adding a intake however it makes up for it during the high end areas
Old Nov 2, 2003
  #75
Novaz3's Avatar
yes it doesnt add to many gains because of its restriction however the reason i purchased this exhaust is because i have a DX and no matter if i went with Greddy, apexi, or dc sports it really wouldnt matter considering my car isnt a power house. Now if elderbrook would make a Turbo for the 2001 model non-vtec civics i might consider a apexi N1 but i wont until Apexi makes a N1 for the Civic and not just a Universal
Old Nov 3, 2003
  #76
mclean987's Avatar
mclean987 is an unknown quantity at this point
ok i was wondering if a 3inch aem cai would lose alot of power if i added a aem bypass valve
Old Nov 3, 2003
  #77
01EXplain's Avatar
mclean987, with a 3in. intake pipe, you would lose your low end torque and throttle response in a trade off for top-end H.P. If you added a bypass valve, it wouldn't noticeably affect the intake's performance. Your only getting a miniscule performance boost with an intake anyways, like at most 5 or H.P.
Old Nov 3, 2003
  #78
mclean987's Avatar
so would a 2/14 or 2.5 pipe make me lose top end but gain on the bottom end ?
Old Nov 3, 2003
  #79
01EXplain's Avatar
Somewhat yes. I think the original AEM and Injen RD intakes both use 2.5 in. pipe to keep air velocity and and vaccum for torque. But I have the Injen RD intake and haven't noticed a significant loss in torque, and got better throttle response and top end power.
Tedverseti
Apr 23, 2020 01:45 PM
UltraHDGames
Jun 8, 2016 05:16 PM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
thaler4cuse
Sep 7, 2015 08:25 PM
