Need answers fast!!
Old Sep 28, 2003
vivid_BLUE's Avatar
make it a habit
vivid_BLUE will become famous soon enough
Question Need answers fast!!
My friend had wrecked his base automatic RSX. He was telling me he was gonna get a Type-s in place of that and I can have his engine (i think it's a K20a3) at a VERY cheap price. He said that the engine and tranny is in perfect condition. What else would I need off of the car if I drop this in my car? Would I need to change my exhaust system with the new engine? I eventually want to do K20a2 engine swap and change my auto to a manual later on down the road when I save up enough money. would I still be able to swap the K20a3 for a K20a2? If so, would it be easier or would it be like starting over?
Old Sep 28, 2003
civicvtec1ps's Avatar
Search and Learn
i wouldnt even bother with automatic k20a3 if you are planning to do k20a2 6 speed swap. not worth your time.
Old Sep 28, 2003
Vinh's Avatar
get a new car....saves all the problems
Old Sep 28, 2003
vivid_BLUE's Avatar
make it a habit
even though the price he gave me was real cheap? I have an auto too.
Old Sep 28, 2003
Search and Learn
whats included.?
this is what you will probably need
K20A2 or K20A3 (from Civic Si) Engine With:
- AC compressor
- alternator
- P/S pump or idler pulley (from Civic Si)
- wiring harness
- exhaust manifold and catalytic converter
- ECU
- Transmission and starter
- intermediate shaft
- Axles from either 02 Civic Si or 94 up Integra GSR (we used 02 RSX with RSX knuckles and hubs)
- RSX or 02 Civic Si subframe
- Hasport ESK1 bolt in mount kit (as of this time the kit will not work with the K24)
- Hasport ESKWH conversion wiring harness
- RSX shifter assembly and cables
- 02 Civic Si radiator and fans (although the RSX will fit with some trimming around the radiator cap opening in the grill)
- 02 Civic Si upper and lower radiator hoses (RSX are longer and may kink)
- RSX throttle cable
- RSX fuel line, brake booster line and purge line
- RSX AC line from compressor to condensor
- RSX clutch lines from the master cylinder to the slave cylinder
- Custom AC line from compressor to evaporator (Hasport should have one available by April)
- 90 Accord negative battery cable
- If you want powersteering:
- RSX high pressure powersteering hose and return line
- 92 Civic P/S resevoir w/ bracket and a section of hydraulic hose to go from the pump to the resevoir
or you could pay him 500 and sell engine on ebay for 1500
Old Sep 28, 2003
vivid_BLUE's Avatar
make it a habit
I can basically get almost everything I need off of that car, but to change to type-s I would have to change all of that again?
Old Sep 29, 2003
IronFist's Avatar
Dude if you're gonna do a type-S switch don't bother doing a base RSX swap first. Just wait until you're going to do the typs-S.
Old Sep 29, 2003
Vinh's Avatar
for realz
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
solarpunk70
Apr 12, 2016 11:43 AM
Islesfan
Sep 29, 2015 03:42 AM
IronFist
Sep 25, 2015 07:13 PM
Jrosa
Sep 14, 2015 08:24 PM
