Injen CAI Question (whistle Sound)
Old Jul 31, 2003
liqdeznutz's Avatar
liqdeznutz is an unknown quantity at this point
With the Injen CAI on our cars, does it make sweet sounds such as a little whistle when changing gears because i have an Injen CAI on my ex coupe and the only time i hear my Injen CAI is when i turn off the car and thats when the Injen CAI turns off...... I've heard it on my friends integra and other cars and when they change from 2nd to 3rd gear and accelerate you could hear their CAI throw out a deep whistle sound.
On my car, you hear nothing..... is that how it is on our cars if not what can i do to fix that???
thanx.
Old Jul 31, 2003
liqdeznutz's Avatar
also when my car is idle i hear a slight thumping coming from the engine bay, but it only happens when in idle mode. please help i need some answers fast dont know if this is normal. thank since I'am really new to this.
Old Jul 31, 2003
cdmx's Avatar
Have you attached your CAI right? the thumping is probably the CAI rubbing against some metal......Also do you have a generic strut bar? mine used to realllly rub that i fixed that tho...not good for the engine.
To answer the first question....Mine whistles but not sure about it whisteling while i shift gears....Most likely they have a better intake a thicker diameter piping...Ive got this one friend with a 3" piping CAI and his is much louder than mine.
Old Jul 31, 2003
liqdeznutz's Avatar
What do you suggest i do , because my intake doesnt even whistle one bit and that thumping sound is getting annoying when iam in iddle position should i try to reinstall my injen cai again?
thank you for your response.
Old Jul 31, 2003
Green Civic's Avatar
Look for rubs on the CAI or the bar, if you have one. Check to make sure all the screws and nuts are tight.
Old Jul 31, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
that swoosh sound just depends on the intake and filter
i had a obx sri with a blitz filter and u could hear that swoosh sound when i shifted, it wasnt loud, but you could hear it and tell it was the intake, as for the thumpin sound, it prob the intake hitting something, as someone stated, just check the cai and strut bar for rub marks and adjust the tubing, if you dont see anything, let the car run, pop the hood and see if it does it then, and look for where its hitting
Old Jul 31, 2003
5PEED EX's Avatar
5PEED EX is an unknown quantity at this point
Injen CAI dosent make that whoooosh noise, it makes deep sucking noise when you hard-step on the gas in any gear. The only one i hear that makes real woooshh noise was R1 cheap *** intake on my friends 97 EX. That thing sounds like turbo, and its only 95 dollar intake. And i payed 250 for my...
Old Jul 31, 2003
xtiszx's Avatar
Cracka
hehe im selling my R1 Intake for 30 bucks,
Old Jul 31, 2003
xtiszx's Avatar
Cracka
oh what? no one wants it?
lol
Old Jul 31, 2003
NCStyle's Avatar
Lax Playa
NCStyle is an unknown quantity at this point
yeah i have an AEM but still had some sound problems, i didn't have all the connectors tight enough and it was moving around, MAKE SURE that everythign is tight enough so that u can't move the pipes w/ ur hands
Old Jul 31, 2003
cdmx's Avatar
I used zip ties cause mine didn't bolt up perfectly
Old Jul 31, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
kinda off topic but does the fipk II make that whistle or swoosh sound when u switch gears?
Old Jul 31, 2003
khmaitiger's Avatar
khmaitiger is an unknown quantity at this point
ill give u 20 for it
trevor
Nov 16, 2001 05:02 PM
trevor
Nov 15, 2001 05:59 PM
se7en
Nov 12, 2001 10:13 AM
Daniel420
Nov 9, 2001 08:36 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
