AEM Altenator Pulley
Old Jul 15, 2003
TiM3's Avatar
TiM3 is an unknown quantity at this point
Well I just bought the AEM Altenator Pulley off ebay but not the whole kit. Only the pulley, replacement belt, and installation instructions. I just want to know if this will help or is it pointless without the power steering pulley? Thanks.
Old Jul 15, 2003
Satanic-Hamster's Avatar
Satanic-Hamster is an unknown quantity at this point
you just answered your own question
Old Jul 15, 2003
TiM3's Avatar
uhhh, ok its late and I am out of it. Can you please explain b/c I don't understand?
Old Jul 15, 2003
prawdigy's Avatar
prawdigy is an unknown quantity at this point
you arent gonna ne power really from pulleys overall... but u need power for at least ne thing..
Old Jul 15, 2003
TiM3's Avatar
I'm not quite sure you guys understand my question and please reply if you actually have had personal experience or direct knowledge. Thanks for trying guys, but I need more information than a just a few words.
Old Jul 15, 2003
well, you see.... AEM pulleys are smaller than the OEM pulleys so when the belts rotate, power steering pump pulley and the alternator pulleys actually rotates lesser in revolution than the OEM pulleys. Because the power steer and alternater pulley rotates less, lesser power is given to them and it gives more power to the engine.
My point is, since you got the alternator pulley only, the belt won't fit. It'll either be too loosen or too tight. If you could get a different belt, it might work, but for now, it won't work
Hope this helped!
Old Jul 15, 2003
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
If they are smaller shouldn’t they rotate at a higher revolution? More power is giving to the engine cause they are lighter and therefore requiring less power to move them. (Thats how I tink they worked)
Old Jul 15, 2003
djmota's Avatar
the pullies are BIGGER hence less rotation on the accsesories. Lighter wieght helps a bit also. IMO its a waste to only have the alt pully on, since the alt does not drain on the motors power very much. Also the belt will probably be too big.
Old Jul 15, 2003
TiM3's Avatar
Thanks guys, that helped. I guess I'll have to look around for the power steering pulley only.
Old Jul 15, 2003
good luck!
Old Jul 15, 2003
HondaLuver's Avatar
Its a celebration bitches!
i have the lower pulley and belts because i was in a crash so i got a new set and only needed the upper pulley. i'll sell you the lower pulley and 2 belts for a 100 shipped... they are brand new and silver, not like that matters because you won't see it...
pm me
btw you can't put on that pulley by its self you need the right belt, it could be too small or big...
Old Jul 16, 2003
poor jaysun's Avatar
poor jaysun will become famous soon enoughpoor jaysun will become famous soon enough
You gain 1HP with every pound lost on pulley weight
Old Jul 16, 2003
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
i would expect the pullies to give better throttle response too, since they're easier for the engine to move, they'll spin with less rotational weight.
Old Jul 16, 2003
TiM3's Avatar
Are you just guessing or you know that for a fact?
Old Jul 16, 2003
5PEED EX's Avatar
5PEED EX is an unknown quantity at this point
All i know, the crank pulley is bitch to take off. Make sure you got the strong *** impact gun and big compressor if you're gonna do it yourself. For some reason I hear weird noise from my engine when its cold and at lower RPM's. Is it due to pulleys being replaced or what ?
Old Jul 16, 2003
TiM3's Avatar
Oh there's no way I'm doing it myself. I'll just have a local shop do it for me. I have no idea about your crank shaft though.
Old Jul 16, 2003
AllMotorSi's Avatar
AllMotorSi is an unknown quantity at this point
I've got both of them installed at a local shop in T.O. and the cost of installing is almost as much as what I payed for the puliies. I felt a little more power in both low and high rpm's. Not the cheapest mod, with minimal gains.
Old Aug 5, 2003
NoSpleeny's Avatar
NoSpleeny is an unknown quantity at this point
The belt should fit without the Power Steering pulley. The reason is that the power steering belt attaches to the crank shaft seperately from the alternator and AC compressor.
There's 2 belts on the right side of your engine...
1 of them is the power steering and crank shaft.
1 of them is the alternator and AC compressor and crank shaft.
Old Aug 5, 2003
cdmx's Avatar
why not just wait and get all the pullies and put them all on at the same time
Old Aug 5, 2003
NoSpleeny's Avatar
Cuz I bought the alternator pulley and it's VERY VERY rare to find the PS pulley alone
Old Nov 23, 2003
cdmx's Avatar
I found one for 55 plus shipping from ANY dealer that deals with AEM....
well the 55 was from one specific dealer.
Bonobo
Oct 2, 2015 06:58 PM
AffliictiioN
Sep 16, 2015 02:21 PM
stank
Sep 16, 2015 07:40 AM
Hatchness
Sep 14, 2015 09:02 AM
