HIDs and Retrofitting Discuss HIDs bulbs, ballasts, projectors and custom retrofits here.
loose headlight bulb
Old May 16, 2015
terry_tr6's Avatar
terry_tr6 is an unknown quantity at this point
I just got my first honda, a 2010 civic and the PO had a Xentec HID setup in the low beams, one of which doesn't always turn on. I started to go back to standard 9006 bulbs but found that the first bulb i replaced(drivers side) is loose in the headlight mounting socket and can wiggle around. Is there supposed to be a foam gasket or something to take up the slop, or is there a way to tighten up the mounting tabs?
I am on a tight time schedule to do this and would like to not have to pull out the whole headlight if at all possible.
Old May 16, 2015
terry_tr6's Avatar
Re: loose headlight bulb
duh.... never mind. once i quit trying to cheat and pulled the battery so i could really get to the socket it was obvious i hadn't seated the bulb completely....
got to stop working on stuf after midnight
Old May 16, 2015
Poopies's Avatar
Super Moderator
Sometimes the mood just hits you!
cferry7
Oct 18, 2015 06:32 PM
MichaelLW
Sep 14, 2015 07:15 AM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
