noise when turning in front end
Old Mar 27, 2011
crazyj_84_99's Avatar
stevn
crazyj_84_99 is an unknown quantity at this point
Talking noise when turning in front end
when i turn the car moving at speed it make a grinding noise or rubbing noise from the front end? only when your moving at speed will it make the noise is it the struts worn out or major problem?
Old Mar 27, 2011
MelJ's Avatar
Trance Addict
Re: noise when turning in front end
Could be. You should check other major components like your CV axles as well. Mine got to the point they would grind while driving in a straight line. The problem started out as a click when turning.
Old Mar 27, 2011
dampers do grind noises?!? semantically, you have double wishbone suspension, so you do not have struts. semantically speaking.
TomSchaeffer
Nov 2, 2021 07:31 AM
chuffsy
May 15, 2015 12:50 PM
pheaton
May 4, 2015 08:26 PM
edgenet
May 2, 2015 08:00 PM
GH04si
Apr 15, 2015 08:13 PM
