electrical gremlins
electrical gremlins
Hi I have a 91 civic hatch back and I am ready to drive it off a cliff, set it on fire, and then blow it up. Anyways so I have an intermittent problem the car dies usually when i've had the heat on for a while or when it gets hot inside the car, and usually happens when i've had the hazards on, it sputters then runs fine then dies, crank it runs then dies, crank it runs then dies, crank and then really doesn't start, roll down the windows let it sit for 30 mins starts and runs fine ahhhhhhhh! so a few months ago I discovered I was only getting 3volts to the ignition switch so I replaced it and the car has been running fine until today, and so the process continues. also I currently have ms1 running on fuel only so that makes me feel pretty certain its not fuel related and I replaced the alternator recently aswell. Anyways any thoughts would be appreciated.
Re: electrical gremlins
I have replaced that a few years ago its possible, but I don't that it would break so soon. i'm more leaning toward something related to the ELD at this point because I had weak spark and I have an msd!! also I do spend most of my time driving at night at idle, accelarating and decelarating because of city driving, and when the charging system is at full load the battery drops to 11v sometimes.
KylesDad
Mar 28, 2009 11:05 AM
Boilermaker1
Oct 4, 2002 12:59 PM
