Essential wires only
Old Feb 4, 2018
John Remsik's Avatar
John Remsik is an unknown quantity at this point
1st post here so be gental.
I have a 92 civic hatchback with a 1.5 vtec,and a 5 speed.
Im making this into an offroad circle track racer.
What wires do I need to keep to start and run the engine? Leaving the alternator on and there is no power stearing
Old Feb 4, 2018
Colin42's Avatar
Re: Essential wires only
Ignition, fuel injectors, crank sensor, vtec wires, oil pressure sensor, water temp, front o2 sensor, probably some other things as well
Old Feb 5, 2018
Everything that's already on it
If you wanna disconnect wires, you probably won't be needing headlights and turn signals
Old Apr 7, 2018
correct. Its a circle track car. I wont be needing anythig but the essentials.
Thanks
Hwoody77
Engine Swaps
Aug 13, 2004 03:28 PM
taz757
Engine Swaps
May 30, 2004 04:09 PM
RSDCivic
Jul 15, 2003 06:50 PM
