1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Electrical Gremlins
Old Jan 15, 2013
BombSquad91's Avatar
BombSquad91 is an unknown quantity at this point
Electrical Gremlins
1989 Civic DX Hatch 5spd D15B2 motor
170 amp Alterstart alternator
0 gauge wire from battery to starter
0 gauge wire from battery to under hood fuse box
0 gauge ground wire
First symptom:
My battery light in my cluster is flickering. Not flashing, flickering. At idle it stays off. When I rev the engine it flickers lightly. When I'm in gear and giving it throttle it flickers almost to the point of strobing.
Second symptom:
The other lights in the cluster all glow slightly at high RPM's.
Third symptom:
Battery seemingly dying. Ill turn the key to start and it will half crank then stop and my Voltage meter will say LO. I wait a few minutes and the car stutters to a start.
Fourth Symptom:
I have a Stinger digital voltage meter. It jumps from 12v to 13.8v while I'm driving. The alternator tops out at 14.1v under full throttle. That's normal. But sometimes ill be driving and it will stay at 12v then jump to 13.2 like its supposed to then drop back down. The fluctuations are completely random.
Any ideas?
Troubleshooting suggestions?
Thanks in advance.
Old Jan 16, 2013
go-part's Avatar
Former Sponsor
go-part is an unknown quantity at this point
Re: Electrical Gremlins
I would start with checking all the fuses and relays.. then check all the wires and connectors.
Old Jan 16, 2013
sailesh's Avatar
sailesh is an unknown quantity at this point
If the battery is in good condition, then maybe the voltage stabilizer..
Old Jan 19, 2013
Update:
When I turn the key to the on position the lights in the cluster that stay on are the signal light indicators and the high beam light indicator. When I turn the key to start nothing happens. Then I pump the clutch a few times, the indicator lights shut off, and I turn the key and the car starts like normal. Then again when I'm driving the battery light flickers, the voltage jumps around, and the indicator lights flicker.
Old Jan 21, 2013
clpowell's Avatar
clpowell is an unknown quantity at this point
possibly a bad diode pack on the alternator
you could possibly stop by an autozone or orielly's they both give a free battery and alternator check.
cferry7
Oct 18, 2015 06:32 PM
Solo Flow
Oct 4, 2015 07:52 AM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Bruce2
Sep 27, 2015 08:45 PM
beanhead
Sep 24, 2015 12:04 PM
