1995 Civic DX timing belt sliding.
Old 2 Days Ago
greiphinn's Avatar
greiphinn is an unknown quantity at this point
I just replaced the timing belt, tensioner and water pump on my 1995 Honda Civic DX. When I run the car the timing belt starts to slide towards the edge of the pulley. Because I'm scared of it coming off I haven't actually run it long enough to see if it will settle or slide all the way off. Ive tried measuring the pulleys while cranking it by hand and they don't seem to wobble or be bent. I've also tried messing with the tension on the belt to no avail. Any ideas as to what is causing this? Should I keep running it and see if it will settle or is it not worth the risk and I should correct this misalignment first?
File Type: mov
clintonium
Oct 8, 2012 06:17 PM
CivicTTurtle
Jan 3, 2012 12:47 AM
griff68w
Dec 1, 2011 10:05 AM
hurtingbad
Sep 24, 2009 04:24 PM
V-8 who?
Aug 7, 2006 08:37 PM
