crank no start,someone please help!!
Old Jul 15, 2023
timm2fast's Avatar
timm2fast is an unknown quantity at this point
Arrow crank no start,someone please help!!
95 honda civic dx,with the 1,5 non vtech motor..i have done so many things and still,the injectors wont spray..ok im getting spark,,ive got good fuel pressure,,ive replaced the distributor,which has the internal coil and crank sensor,ive replaced the maf sensor,ive swapped out the tps sensor,ive checked for pulse(good),ive made sure it was in time,even put on new belt,,ive sent the computor to a proffesional and it works as it should,,ive put new plugs in it,ive checked fuel pressure its good,ive checked to see if the gas return line is kinked or clogged its not,,ive took a injector off and bench tested it and it sprayed perfect..ive checked most or all my grounds..at this point im at a dead standstill,anyone can u please help if ive missed something,,it cranks over and over but the injectors refuse to spray fuel ,,i am stuck and seek guidance on this please..
Old Jul 16, 2023
Colin42's Avatar
Re: crank no start,someone please help!!
Main relay? And any other relay that is connected to the fuel pump and injectors
Jmk85
Aug 28, 2022 07:52 AM
Randall Charles
Jun 9, 2019 02:44 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
EM2 Bluez
Oct 19, 2006 03:41 AM
