Question
Old Jan 2, 2022
Rickbobbie's Avatar
Rickbobbie is an unknown quantity at this point
Question
Curious if anyone can help
Old Jan 2, 2022
Wankenstein's Avatar
Re: Question
Is it cranking but not starting/running?
What test did he do for spark quality? If spark is weak it may prevent not from running. Watch the video in my signature at the bottom of this reply.
Has he verified mechanical (crank/cam) timing? The timing belt may have jumped teeth and effected timing?
He replaced the ECU?
Is he sure fuel is getting to the end of the fuel rail? An easy test is to remove the return line (to gas tank) from the fuel pressure regulator, have a helper crank the engine while he catches the fuel with a jar or small plastic bucket that comes out of the FPR.
To test the injectors pull all of them from the head and catch the fuel in a bucket while a helper cranks the engine. He should observe the injectors spray pattern as well during the test. Ideally they should spray evenly and in a similar spray pattern to each other.
civicsato
Sep 23, 2009 09:55 AM
Thuener
Nov 6, 2005 08:06 AM
phuzion420
Mar 30, 2005 10:24 AM
jiggerachi
15
Apr 2, 2004 03:05 PM
AnchorBlueMan01
Dec 3, 2002 10:14 PM
