Misfire at high rpms!
Old Sep 22, 2015
NROD315's Avatar
NROD315 is an unknown quantity at this point
So i've been having this problem for awhile and i've been trying to look around and find answers but i have not found anything for it. My car misfires and hesitates at rpms higher than 4-5k when the throttle is more than 50% open. It was new wires and the plugs are all in good shape. I was having the problem before and replaced the dizzy to one equivalent to OEM. The problem stopped then started again after taking my car on a 2 hour long road trip. Theres no code for a misfire but there is a lack of power and the tach needle floats at the higher rpm. What else is there to check or do?
Old Sep 22, 2015
Re: Misfire at high rpms!
Floats higher than actual RPM?
Look for loosely fitting terminals on the igniter, or maybe someone missed a spade when they connected the wires to the igniter.
See this TSB; ignore the codes listed......read the repair procedures
http://www.tegger.com/hondafaq/p0420/A05-027.pdf
The only equivalent to OEM is genuine Honda parts. Aftermarket remans are just crap.
Old Sep 23, 2015
NROD315's Avatar
im gonna take apart the distributor today and look at that thanks! and the needle on the tach will just jump around after 5k, (it wil just go up down say like to 8k and drop to 6k but the motor will misfire but slowly increase it wont steadliy increase.) It seems like it takes forever to hit the limiter.
ZSKCivic01
Jan 29, 2002 06:09 AM
ripper
Jan 28, 2002 02:00 PM
Aznnp77
Dec 13, 2001 04:03 PM
ModNewbieHELPME
Nov 30, 2001 06:13 PM
