is my starter going bad
Old Sep 10, 2012
93honda's Avatar
93honda is an unknown quantity at this point
My 93 has been starting but today I went to start it and there was a click then I turned the key again and it turned over. I checked the battery connectors and the hot was a bit loose. I tightened it and it turned over. Now is my starter going bad or was it just my battery cable being loose. Its really hard for me to tell considering it turned iver before I tightened it
Old Sep 10, 2012
Re: is my starter going bad
could just be loose. altho ive seen a bad starter just click once and do nothing. may also be a loose cable so watch if it happens again. if it does, replace starter.
Old Sep 12, 2012
93honda's Avatar
Thanks ill give that a try
Old Sep 17, 2012
kellogg6316's Avatar
kellogg6316 is an unknown quantity at this point
the only ground the starter has is through the transmission case so after build up of grease and dirt a good ground can be lost. You rig up a wire from the negative battery post on your own though.
Old Sep 18, 2012
same goes for the direct power line to the + battery from starter motor.
cukaracha
30
Jul 26, 2015 12:01 PM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
CivicsClass101
Jul 9, 2015 11:14 AM
Bounddyy
Jul 8, 2015 11:22 AM
cgavin1
Jul 7, 2015 07:10 AM
