Effin horn!!!
Effin horn!!!
I am new to site and im sure this issue has been brought up before. Just bought a 93 honda civic DX with the d15b7 motor and standard tranny. The horn does not work and I live in missouri and must get a inspection done on the car. I tried the horn hooked to the batter and it works. when i hook up a test light to the car and try both wires, one lights up and the other doesnt. when i test the fuse underneath the hood the test light lights up. Does anyone have any other suggestion on what to do?
Re: Effin horn!!!
One needs to be positive at all times, the other needs to go negative when the button gets pushed. Which one ain't doing what it should?
I would split the system by testing everything from the horn relay. You would have all 4 terminals to test and figure out which direction to go in short order.
#1 can you HEAR the relay click when you push the horn buttons? It is next to the fusebox under the dash.
Blu/yel = +12v from the horn fuse
one blu/grn = grounds when the button is pushed
the other blu/grn = ground to the horn
blu/red = body ground
Jumper the last 2 to honk the horn from the relay socket.
If it has an airbag, is the SRS light on? Check codes.
Clockspring could be shot.
An understanding of the system, and a few simple tests, should lead you to a definite answer. No guesses.
HTH
MamaBear2015
Sep 24, 2015 11:34 AM
18
Aug 17, 2015 08:02 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
