i need someone that knows what about camber
Old Jun 26, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
i have a 94 civic ex and i need to know if the camber on the front can be fixed with just a simple front end alignment or do i need to buy the camber kit
Old Jun 26, 2011
Re: i need someone that knows what about camber
You're gonna have to get a camber kit.
I'm assuming you've just lowered your car, yes? Or at least planning on lowering in the near future?
Old Jun 26, 2011
BlueEM2's Avatar
Whachya lookin at?
It depends on if its lowered or not. If the car is lowered its probably beyond the stock adjustment capability for camber adjustment. If it's not lowered they can usually adjust it so the alignment is correct. The front camber kit is pretty cheap.
Damn Josh we wrote at the same time but you beat me!
Old Jun 26, 2011
turbo_coupe_EJ1
the car isnt lowered neither do i plan on lowering it
Old Jun 26, 2011
BlueEM2's Avatar
Whachya lookin at?
They should be able to adjust your camber back to spec but the camber shouldn't be out... Is something broken or worn?
Old Jun 26, 2011
turbo_coupe_EJ1
well it need a bushing kit on the front end would that cause it then
Old Jun 26, 2011
BlueEM2's Avatar
Whachya lookin at?
Fix your bushings before you get an alignment done. Then ask the alignment shop if they can fix your camber without a kit if it's still out. sdaidoji (Sandro) is the guy on here that probably knows the most about suspension he would be able to answer your question for sure. If you have a stock front end you shouldn't need a camber kit however.
Old Jun 26, 2011
turbo_coupe_EJ1
ok thanks
Old Jun 26, 2011
Tbohar is right.
If everything is in good shape, they should be able to adjust - the adjustment is just done by moving the knuckle bolts inside the holes in the knuckle - not a lot, but if nothing is damaged, it should be possible.
if not, time to find out what is bent or bending to cause excessive camber (bushings shot means they will squish under pressure and give the excess camber)
Old Jun 26, 2011
turbo_coupe_EJ1
ok thanks
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
